Thread: U bend behind catalytic converter
Results 1 to 20 of 36
  1. #1 U bend behind catalytic converter
    Kemmerer, Wyoming
    When I started modding this car, I had a mechanic install the headers, and when he did, he left the U bend behind the catalytic in place instead of using the downpipe that came with the headers. I'm wondering if this is causing much, if any, restriction. The car is a 2001, and I wanted to keep the rear O2 sensor because of the catalytic converter diagnostic. I have since disabled the diagnostic so I don't care if I keep the rear O2 sensor and the catalytic converter. I have Speed Daddy headers, and with the little amount of searching I have done, have not been able to find another Speed Daddy header downpipe. So I am wondering if the catalytic converter that I have and the U bend behind it is causing enough of a restriction that I need to find something to find another downpipe to replace it with, and if so, has anyone tried a ZZPoop downpipe with Speed Daddy headers?
    https://drive.google.com/file/d/0B6K...ew?usp=sharing
  2. #2 Re: U bend behind catalytic converter
    Antioch, IL
    3,400 posts and 20k chats, and your still retarded and asking noob 101 safely modifying 3800 thread questions
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: U bend behind catalytic converter
    god lord, theres your low timing and kr issues. get rid of that asap.
  4. #4 Re: U bend behind catalytic converter
    Kemmerer, Wyoming
    not sure why I didn't notice this before.
  5. #5 Re: U bend behind catalytic converter
    Antioch, IL
    because your not your own mechanic, a reason why we all wrench our own crap, we know whats fking done!
  6. #6 Re: U bend behind catalytic converter
    Kemmerer, Wyoming
    what would be the cheapest, easiest solution to this?
  7. #7 Re: U bend behind catalytic converter
    Antioch, IL
    put your down pipe on
  8. #8 Re: U bend behind catalytic converter
    cut the u bend off the cat weld new pipe to a flange and bolt it back together, nothing a muffler shop cant handle. or buy a high flow cat, screw that stock crap.
  9. #9 Re: U bend behind catalytic converter
    cut the u bend off the cat weld new pipe to a flange and bolt it back together, nothing a muffler shop cant handle. or put a glass pack in place of the cat, because you don't live in a hippie tree hugging state that requires emissions, screw that stock crap.
    Fixed
  10. #10 Re: U bend behind catalytic converter
    Kemmerer, Wyoming
    what difference would a glass pack make if I still have the stock resonator?
  11. #11 Re: U bend behind catalytic converter
    Antioch, IL
    ugh close this thread, lock it he is getting out of control!
  12. #12 Re: U bend behind catalytic converter
    Quote Originally Posted by SgtMarshal View Post
    Reduce rasp and drone, also replace the stock res with a glass pack.
  13. #13 Re: U bend behind catalytic converter
  14. #14 U bend behind catalytic converter
    Quincy, Mass
    Have the shop cut it out and run a straight pipe to the res, no cat no ubend
    No more GP 04 Impala SS Indy:
  15. #15 Re: U bend behind catalytic converter
    Nov 2011
    NY
    Sgt. Must be living in one of those Fed Free Marijuana zones... Puffing much?
    lolz...
    just lol...
  16. #16 Re: U bend behind catalytic converter
    I'm gonna lock this for the next ignorant question Marshall asks.
    Also that's strike two after he told that crazy nut from facebook to personally message me.
    GO RESEARCH GUY THAT IS ALWAYS HERE. These questions shouldn't ever be asked lol
  17. #17 Re: U bend behind catalytic converter
    Kemmerer, Wyoming
    Can you just delete the thread
  18. #18 Re: U bend behind catalytic converter
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I had to jump in before the lockdown, I couldn't resist...
    Put the damn SD downpipe on and worry about the rest later.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  19. #19 Re: U bend behind catalytic converter
    Kemmerer, Wyoming
    I would if I still had it
  20. #20 Re: U bend behind catalytic converter
    I'm gonna leave it open because this is hysterically silly.
    Why on earth would you not have just used the crappy gooseneck is beyond me lol
  1. Catalytic Converter?
    By Lawenforcer in forum General Tech Discussion
    Last Post: 02-21-2012, 02:53 PM
  2. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  3. Bad Cat Converter and O2 sensor. U Bend Delete?
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 04-28-2011, 07:45 PM
  4. I need to no were i can get a catalytic converter.
    By krazyog1 in forum 04+ Specifics
    Last Post: 10-06-2009, 03:53 PM
  5. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
