Thread: I have spark, fuel and it cranks but no start
Results 1 to 20 of 34
  1. #1 Re: I have spark, fuel and it cranks but no start
    Nov 2015
    WI
    DMM=Digital MultiMeter
  2. #2 Re: I have spark, fuel and it cranks but no start
    Nov 2015
    WI
    Are you sure your fuel pump is good? I know you changed it but maybe it wasn't a good one? It run runs if you add secondary fuel but sometimes u get bad parts.
  3. #3 Re: I have spark, fuel and it cranks but no start
    Jan 2015
    United States
    I'm only going to suggest this because it seems like you have tried all the obvious stuff. I had somewhat similar symptoms on a late 90's GM truck where it would run on starter fluid and occasionally run for a trip and then fail to start the next time. I'll skip all the trials and errors but for me ultimately it was a battery that was only slightly failed. It wasn't storing at 12v more like 7-8-9v. Enough to run the fuel pump and sometimes supply full pressure but sometimes not. If it did fire up the alt would give 14v and keep stuff running for 1 trip.
    Anyhoo good luck - but maybe check your batt voltage both at rest and during crank.
  1. Replies: 6
    Last Post: 07-20-2021, 09:27 PM
  2. Car cranks but no start. Fuel injectors not releasing gas
    By Shiftingshaddow in forum General Tech Discussion
    Last Post: 04-20-2016, 06:58 AM
  3. Won't start, has fuel and spark
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2014, 05:32 PM
  4. have spark and fuel pressure. no start
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2012, 12:26 PM
  5. HELP car won't start, got fuel, got spark, got air?
    By bezemom in forum General Tech Discussion
    Last Post: 05-29-2009, 02:19 PM
