Thread: Won't start, has fuel and spark
Results 1 to 20 of 31
  1. #1 Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    Been plagued with a rich fuel trim prob so I chased down a leak to the supercharger gasket, still leaked after the first one so I pulled it apart and put another new one in. It ran before I re- replaced the gasket. I have fuel pressure, spark plugs are wet and I have spark but it won't run. Here's a short vid, I also have a scan from hptuners if interested.
    http://www.youtube.com/watch?v=NeGzdRGDFmo
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Won't start, has fuel and spark
    Did you double check everything was plugged back in? How did you determine you have spark?
  3. #3 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    I believe so. I have a spark tester that you plug one end on the plug and the other in the boot and it lights up as you crank. I did this all at the coil as this motors in a fiero and is a biotch to get at the front 3 cylinders.
  4. #4 Re: Won't start, has fuel and spark
    Pull one of the plugs that are easy to get at and leave it in the plug wire and lay it against the block and see if you can see spark.
  5. #5 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    I should have mentioned that in my last response, oops. Yeah I did that but I grounded it on the strut tower bolts and yeah there was spark there. And my fuel pressures around 45ish on the guage.
  6. #6 Re: Won't start, has fuel and spark
    Either the firing order is off or there is a massive vacuum leak somewhere.
  7. #7 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    I never touched the firing order myself. I figured it might be a vacuum leak so I pressurized the intake through the throttle body and there was a very slow leak down, less than before when it was running.
  8. #8 Re: Won't start, has fuel and spark
    Spray some starting fluid or brake cleaner in a vaccum line or unplug the MAF sensor and try again.
    Something is not working together, maybe a vats code or something.
  9. #9 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    I could try the starting fluid to see if it'll run that way. I did previously disconnect the maf but no change.
  10. #10 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    I tried starting fluid through a vacuum port on the top of the motor(octopus) and no change in the way it's turning over.
  11. #11 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    I was playing around testing the icm and crank sensors as per
    http://easyautodiagnostics....gnition_module_1.php
    I followed it through and all is good until i got to part 6 where you test the signal from the 3x and it says if the led blinks, the ICM is bad. Well mine blinked, but i have spark.. Confused.
  12. #12 Re: Won't start, has fuel and spark
    it can happen like that. the icm maybe throwing the sparks at the wrong time or weak spark.
    if you got a junk yard near by pick up a used one and swap it.
  13. #13 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    the problem with our junk yards is that they want similar to new prices for old crap. Theres one about 6 hrs away and they want $150 for it, I told the guy I can buy a new one from napa for $190, he said thats the best he can do then hung up. Anyone know th epart number for these icm's, I found a couple different ones that look the same but different numbers.
  14. #14 Re: Won't start, has fuel and spark
    try ebay. they are all the same, n/a s/c park ave, montie, regal.
    look up your icm on a parts store site, you'll have one part # to go off.
  15. #15 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    I tried that on one and i got a few different part numbers that they all said would fit and that didn't seem right. But some of the problem is they don't have an option for the supercharged motor.
  16. #16 Re: Won't start, has fuel and spark
  17. #17 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    awesome thanks, i was trying the places i knew, not much in canada. Atleast they had the supercharged option, i didn't think the n/a was interchangable
  18. #18 Re: Won't start, has fuel and spark
    http://www.grandprixforums.net/threa...04#post1191104 heres one listed for 15 bucks. not sure what the shipping to up north will add tho.
  19. #19 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    Awesome thanks for that.
  20. #20 Re: Won't start, has fuel and spark
    Aug 2013
    Kitimat, B.C.
    I quickly replaced the icm and it's still not running. At least before it sounded like it wanted to run and now it just cranks over. I will have to test this one as well when I get the chance.
  1. Replies: 6
    Last Post: 07-20-2021, 09:27 PM
  2. have spark and fuel pressure. no start
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2012, 12:26 PM
  3. Car won't start << No Spark>> please help!
    By Pipeliner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2011, 08:40 AM
  4. No Start, No Spark. Whats up ?! 97 GP GTP
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2011, 03:39 PM
  5. HELP car won't start, got fuel, got spark, got air?
    By bezemom in forum General Tech Discussion
    Last Post: 05-29-2009, 02:19 PM
