Thread: Bad supercharger bearings causing kr?
Results 1 to 20 of 38
  1. #1 Bad supercharger bearings causing kr?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys im trying to pinpoint a kr problem that has came up out if nowhere and i have not done any mods and yet i was kr free and now i have anywhere from 1-4*. Ive noticed my supercharger making quite a bit of noise which i always thought was the coupler but the noise actually gets louder as rpms go up. Which someone on here said the coupler should not make noise unless idling. So considering how ridiculously loud it is, could it be causing false kr?
    Sent from my LG-H811 using Tapatalk
  2. #2 Re: Bad supercharger bearings causing kr?
    sure can, i had a local i was tuning and for the life of me there was no killing the 7 to 9º kr from it. took th ebelt off, and went wot and no more kr.
    it also had kr if revved in park. up to 2º.
  3. #3 Re: Bad supercharger bearings causing kr?
    Well derp there no knock with no boost. Who would have ever thought that would happen.
    Toss some 100+ octane fuel in the tank when you get low on fuel, do a pull or two. If the knock is still present, then it's shouldn't be fuel/ignition related and something else is causing the knock sensors to pick up activity.
  4. #4 Re: Bad supercharger bearings causing kr?
    taking the belt off was to remove the sc from the equation, the 2º in park revved not bouncing off the limiter, belt on was the kicker. thats when i knew for sure it was the supercharger for sure.
  5. #5 Re: Bad supercharger bearings causing kr?
    Oct 2015
    Ya well ive been seing knock when im not even in boost but i can take the belt off and run kr free which is what makes me think its the supercharger itself.
  6. #6 Re: Bad supercharger bearings causing kr?
    Oct 2015
    Hey scotty so i just revved it in park and got 1.5* of kr so you think it could be the suoercharger itself?
  7. #7 Re: Bad supercharger bearings causing kr?
    i would. local guy here went to a gen 5 and no more retarded kr issues.
    gen 3's are cheap and easy to find. gen 5 you can add the cost of the adapter plate as well. or go nuts and get a N* lol
  8. #8 Re: Bad supercharger bearings causing kr?
    Oct 2015
    Ya well i just spent all my money on e85 parts so i think ill have to find a cheapy gen 3 but what about just doing a rebuil on it?
  9. #9 Re: Bad supercharger bearings causing kr?
    that you can also do, bearing kits are pretty cheap, theres a few how to;s floating around.
  10. #10 Re: Bad supercharger bearings causing kr?
    Oct 2015
    Ya i just dont have a press and idk how much a shop would charge or if they would even know how to do it
  11. #11 Re: Bad supercharger bearings causing kr?
    Omaha, NE
    I would give Jon Bond a call. I think his rebuilds are around $750, but I have heard great things.
    http://jonbondperformance.com/index....age=contact_us
    Grand Prixs aren't listed on his site, but he does do Eatons, so I don't see it being too much of a problem for him to take care of it.
    But... Before you do that, are you sure that it's your supercharger bearings and not the coupler?
  12. #12 Re: Bad supercharger bearings causing kr?
    750, gtfo of here , i paid 800 for my whole car lol
    find a used one for a 100 beans.
  13. #13 Re: Bad supercharger bearings causing kr?
    Omaha, NE
    Rebuilds ain't cheap! I'd go find a used one too, but... I still think OP should check his coupler before he does anything.
  14. #14 Re: Bad supercharger bearings causing kr?
    Oct 2015
    Ya i just didnt want to spend 40$ if i thought i might need a whole new supercharger as it us the rotor coating isn't that great on my current one which is why i havent changed the coupler yet. Cause it's like scotty said i coukd go pick up a whole nother one for 60$ more that already has a good coupler and better rotor coating. So ive been kind of torn on what to do
  15. #15 Re: Bad supercharger bearings causing kr?
    Oct 2015
    Hey scotty or someone ive been monitering my egr valve and have noticed it never goes past 55% duty cycle. I dont know a lot about how the egr works but im assuming if im flooring it and theres a lot of load on the engine it should be at 100% duty cycle. Maybe its not opening correctly and this could also cause kr?
  16. #16 Re: Bad supercharger bearings causing kr?
    no idea on the egr, mines gone. and dont think its causing kr anyways.
  17. #17 Re: Bad supercharger bearings causing kr?
    Oct 2015
    Hmm ok well i will let you guys know what happens when i either replace the whole charger or do the coupler. Theres a guy locally that has a min condition gen 3 but he wants 150 for it. It does come with throttle body and all the sensors but i dont need any of that lol
  18. #18 Re: Bad supercharger bearings causing kr?
    Omaha, NE
    You could always unplug your EGR and go for a drive. It'll throw a check engine light if the code isn't deleted, but it wouldn't hurt to rule it out as an option.
    You said your KR came out of nowhere, how long ago did it start? Did anything change shortly before it started? New parts, different gas station or octane, etc?
  19. #19 Re: Bad supercharger bearings causing kr?
    Oct 2015
    I started noticing it about a month ago. I say it came out of no where because of the fact nothing changed i havent modded it anymore, i havent changed the tune, i always use highest octane 91 in Arizona. So im trying to find things that could go bad and cause kr because i had it tuned spot on and now it's all messed up.
  20. #20 Re: Bad supercharger bearings causing kr?
    Oct 2015
    If i unplug the egr wont it just stay closed which would potentially cause more kr since im not getting the "cooling effect" from it
  1. How to replace Supercharger Bearings
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 08-09-2012, 02:08 PM
  2. Supercharger bearings shot!:o no more supercharger?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2011, 02:27 PM
  3. Supercharger causing misfire?
    By mickybaby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2010, 10:22 AM
  4. supercharger bearings???
    By colindunn in forum Off Topic Discussion
    Last Post: 06-03-2010, 02:58 PM
  5. supercharger bearings
    By DOUGLASMELTER in forum General Tech Discussion
    Last Post: 05-09-2009, 01:23 PM
