So i just completed my third topswap. The car ran great for a week and then i decided it was time to start getting the tuning down packed. Scotty helped me out with the bin file to start off with, i loaded the file and that was the last time it started. Its been about a week now since its ran and im literally out of options as far as what to do to get it running again. So far i have changed the coil packs(No the ICM, Just the coils) Crank and cam sensor, MAF, Vac lines, spark plugs, and MAP sensor. She will burp all day but refuses to fire up. Im getting spark all the way through. The wiring harness has been probed a million times to check for ground and everything checks out. Im getting fuel to the rails and fuel from the injectors so at this point im at a total loss. Would anybody have any insight to something im missing? I was told that maybe i should change the ICM but im waiting before i put more money into it. Any help would be very helpful. And before i forget ive done the security relearn with no luck. I have DHP but it doesnt help much, the only code it throws if for the Bypass sol since i have it deleted. And if it was a vac leak preventing the car from starting where would i even begin to look?
