Thread: Help with my GTP
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Help with my GTP
    Oklahoma
    Yep, the second time it went bad, it would just die. When I started testing the thing I would sit in the car and let it idle and usually between 5-10 minutes it would just shut off like I had turned the car off myself.
    When I saw I had no spark on the #1 cylinder (thanks to the help of people on here) I got to work replacing the CPS and had no issues afterwards.
    I started collecting dead/used sensors so I could start doing write ups on how to test them and determine they are bad but Im no where near having that completed. Furthermore, the CPS is one of those finicky sensors. Its based on Hall effect electronics and they can fail when its hot and then work fine when its normal ambient temp. With the work required to pull it off the engine its just better to replace it and be done with it.
  2. #22 Re: Help with my GTP
    Feb 2009
    moundsville
    i can actually here the fuel pump kick off before the car stalls.. i think i forgot to mention that.. and with the cam sensor do you think i should change that while i'm in there also? or have u heard of those failing before?
  3. #23 Re: Help with my GTP
    Feb 2009
    moundsville
    what kind of supercharger oil should be i run cause i just noticed mine is dry.. would that make the car stall? still free spins tho its not seized up?
  4. #24 Re: Help with my GTP
    Oklahoma
    The fuel pump could be an issue and it could be a reaction to the CPS failing too as the engine shuts down from no spark. What I would do is test the fuel pressure and see what you have when the engine is running and leave the fuel pressure tester hooked up and see if you get a drop in pressure as the engine shuts off. Even after the engine shuts down you should still have around 40-45 psi there.
    I have not heard of any real issue with the cam position sensor so I guess that would be a toss up whether or not you replace it. I dont see any harm in doing so but I know of no real issue with it.
    As for the supercharger oil, you can get supercharger oil from the GM dealership, I think it runs about $8/bottle and you'll need two of them to do a complete fill on it. If its spinning freely and no knocking or grinding sounds when you spin it by hand you're probably okay. My question would be why is it drained out. So I would be looking for any leaks in that area.
    That all said, Ive run motor oil in the supercharger before. I ran a synthetic 0W-20 in it since it was about the same viscosity as the supercharger oil and can deal with the heat. However, I have no long term results on that as a couple months after I started testing that I lost the differential in my car and have not yet got it back on the road.
    You'll get a mixed response on whether or not you can use motor oil in the supercharger. I had no problems in using it in the time I did and the snout was a bit cooler with the synthetic motor oil than it was with the GM oil. If you have any reservations then use the GM supercharger oil. Im willing to take the risk to test such things out and to find out for sure, some arent. If you choose to run a motor oil do not run anything other than a quality full synthetic and I dont think I would run anything other than a 20 weight in it. Ive heard of 5W-30 being used, but again, I havent tried that out and dont have any substantial time using the 0W-20. A conventional motor oil isnt going to hold up to the speeds that blower turns.
  5. #25 Re: Help with my GTP
    Feb 2009
    moundsville
    ok thanks for all the help i just finished installing the new fuel pump i let it run for an hour or so just to monitor it a little and see if it stalled so far its a go...
  6. #26 Re: Help with my GTP
    Oklahoma
    Excellent. Im glad you added the bit about the fuel pump then. I dont think, or at least I have not heard of one just shutting off like that before, thats a new one.
  7. #27 Re: Help with my GTP
    Feb 2009
    moundsville
    haven't really got to drive it much tho to see if that's all because i've been at work and haven't had time switch the title..
  8. #28 Re: Help with my GTP
    Feb 2009
    moundsville
    also after i let my car run for a while u can here the super charger clicking almost i think maybe the bearings are going out. Can you rebuild that s/c and wuts it like to do? how much? where can i get the kit? or is it just easier to buy new? Wut about aftermarket any suggestions? I also need Driver exterior door handle, power steering pump, power window switch, blower motor and relay... any good sites or dealers i can order through... you seem to know ur stuff..
gtp
