Thread: Pulley size with water injection
Results 1 to 12 of 12
  1. #1 Pulley size with water injection
    Aug 2016
    Indiana
    Just curious. Hypothetical mod list: Intake, downpipe/u-bend delete, and water injection. What pulley size could you get away with and maintain minimal KR? 3.4? 3.2? 3.0?
  2. #2 Re: Pulley size with water injection
    with out flow mods, aka headers, a 3.4 might be the limit. you also need a tuner.
  3. #3 Re: Pulley size with water injection
    Aug 2016
    Indiana
    Yeah, I should have said tune. It was implied. You don't think the downpipe would be enough huh?
  4. #4 Re: Pulley size with water injection
    Tune or TUNER.
    Because for nozzle and pulley changes, you'll need to tweak it.
    Just get injectors and convert it to E85. Much easier. Better results. I ran a 3.2" on a GenV (which is like a 3.0"~ or so on a GenIII) with a 3" downpipe, 42lb injectors, and was tuned via HPT and a wideband...otherwise stock.
    Methanol is meh.
  5. #5 Re: Pulley size with water injection
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Front manifold is very restrictive.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  6. #6 Re: Pulley size with water injection
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by blueguy View Post
    With my mods in my sig, I am slowly but surely dropping down in pulley size (currently at a 3.2, but working my way back to a 3.0). Curious what your AFR tables were set at on the 3.0/E85 setup with that few of mods? Any suggestions for WOT AFR, PE enable settings, etc.? Sounds like you had it pretty well dialed in. Thx!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  7. #7 Re: Pulley size with water injection
    Enable settings are up to the end user, pretty much a personal preference for what throttle percentage you want it at.
    E85 can be leaner if you want, figure 11.5-12.0 with that fuel should be plenty safe.
  8. #8 Re: Pulley size with water injection
    Mar 2014
    Cincinnati, OH
    Sounds good. I have been in that exact range on this E85 build thus far with good effects. Time to drop pulleys!
    2002 GTP sedan:
  9. #9 Re: Pulley size with water injection
    May 2008
    Schuyler, NE
    E85 is easier if you have access to it. But, spraying meth will give you great results too. You should easily be able to run a 3.2.
    No need for headers.
  10. #10 Re: Pulley size with water injection
    Yup, headers suck.
    Quote Originally Posted by 97AutoXVette View Post
    Pretty sure I was around 19-20* advance (basically a little modded 04+ timing table if I remember right) in the low 12's with AFR. Reptile tuned it since we usually work on stuff together. Couldn't tell you much anything else since I never got into tuning, but I'm sure he has the file. I'd send him a PM on your end and I'll let him know this weekend since we are probably working on a couple things anyway.
    https://www.youtube.com/watch?v=gSCllMsre_U - That was Rynoman on here...pretty much every bolt-on you can do running pump gas on a GenIII...I think he was on a 3.2" or close to that. That car however has a huge stereo and a full interior while my pile was totally gutted from front to back minus the carpet, dash, and two front seats, haha.
  11. #11 Re: Pulley size with water injection
    GTP Level Member
    Jun 2016
    Cleveland ohio
    You definitely need to do something with the front manifold. Either Port, plog, or headers. here are a few pics of my NA 3800 port job. Takes time but helps.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  12. #12 Re: Pulley size with water injection
    Oct 2014
    St Augustine FL
    Quote Originally Posted by rickisrad View Post
    Looks like you added some weld material. Smart. I ported my front manifold years ago and it cracked the manifold after a few months of use. I now use a PLOG and have had no problems.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
  1. Alcohol/water injection
    By scottyk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2012, 01:51 AM
  2. Water Methanol Injection
    By Speedy1973 in forum General Grand Prix Discussion
    Last Post: 07-26-2012, 09:10 PM
  3. water/alchohol injection?
    By 3sportbob in forum General Tech Discussion
    Last Post: 08-21-2009, 09:53 PM
  4. Methanol/water injection
    By gtp59 in forum General Tech Discussion
    Last Post: 04-01-2009, 09:59 PM
