Thread: Lim gasket?
Results 1 to 20 of 27
  1. #1 Lim gasket?
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    So I saw this today and I know I need to do something for sure.
    I've read about this and I've watched a few videos but I still have a bunch of questions.
    So here are the first few questions
    Where is the best place to buy lim gaskets and the supercharger gasket?
    Whats the best brand?
    How long should I expect the job to take??
  2. #2 Re: Lim gasket?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Jaredthefail View Post
    I got mine from Rock Auto.
    GM or Fel-Pro.
    My mechanic buddy did mine. He tore it down Friday night, and finished it on Saturday. He took his time and I think that was around 5-6 hours. A shop being paid would probably be closer to the 3-4 hour range.
    I have a list of the parts I used here.....
    http://chrisb.users.superford.org/Gr..._Manifold.html
    EDIT: Looks like I made a note on my write-up.... book time is 4.6 hours, for NA of course.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Lim gasket?
    rock auto, buy the magnum kit, it costs less and comes with lots of extra gaskets and injector o rings.
    and thats your valve cover bolt with the fluid over it, never seen a lim gasket leak coolant up there, the lim bolts get covered in coolant. not the vc bolts.
  4. #4 Re: Lim gasket?
    Nov 2015
    Olive branch, MS
    I think I'm going to do this myself... The mechanics around here aren't worth a damn.
  5. #5 Re: Lim gasket?
    its only scary looking with the fuel rail and harness all plugged in, once that crap is off its all down hill.
  6. #6 Re: Lim gasket?
    Quincy, Mass
    Here's a how to video that I followed, do your valve cover gaskets and bolt garments while at it. You don't have to do lifters, the ls7 lifters are noisy anyways.
    http://m.youtube.com/watch?v=-2ZbFwTNjhg
    No more GP 04 Impala SS Indy:
  7. #7 Re: Lim gasket?
    Nov 2015
    Olive branch, MS
    So I can get the gaskets ordered today and the coolant elbows too but I have school all week and it's like a 45 minute drive both ways will it be okay to drive this car?
    I watch the temperature really closely with torque pro but I dont know if it will leak more.
  8. #8 Re: Lim gasket?
    yup. drive on
  9. #9 Re: Lim gasket?
    Is that oil or water?
    I'd clean it and see what comes back. LIM's don't typically leak there fwiw
  10. #10 Re: Lim gasket?
    Nov 2015
    Olive branch, MS
    Come to think of it I filled up the oil before I left that day and I spilled some so that is probably oil.
    My dipstick was reading really weird though. I took it out I wiped it off and I put it back in and when I pulled it out again it had nothing. So I freaked out but then I tried the same thing later and it said nothing again, but when I put it in a 3rd time I moved it around a little bit and it said it was full.
    Am I doing something wrong?
  11. #11 Re: Lim gasket?
    Depends.. was the engine running when you checked the engine oil? if yes.. the problem is your method. Turn engine off.
    If you are parked reasonably level with engine off, you should see it. If not.. where did it go?
    As for the gasket.. I'd say that oil looked too clean to me and you spilled it. Wipe if off and cancel your gasket order. Problem that needs to be fixed is between the steering wheel and seat.
  12. #12 Re: Lim gasket?
    Nov 2015
    Olive branch, MS
    There's coolant leaking all down the side of the engine though so I think it still needs lim gaskets. I'll take pictures if that if I get out of class early though
  13. #13 Re: Lim gasket?
    Quincy, Mass
    Which side? Could be a bad water pump gasket or just cracked coolant elbows.
  14. #14 Re: Lim gasket?
    Nov 2015
    Olive branch, MS
    It's the elbow on one side but the other side it's coming out above the coolant temp sensor.
  15. #15 Re: Lim gasket?
    Which is often the end cap where the coolant does a turn around. It's not common for the NA TB gasket to leak, but it can happen. Snap a pic or two. Let's see what you got happening. Then we can guide you to the most cost effective fix.
  16. #16 Re: Lim gasket?
    Nov 2015
    Olive branch, MS
    So this is under the supercharger
    And here is around the coolant temp sensor
    I'll take some by the fuel injectors because there's a lot of crap next to them
  17. #17 Re: Lim gasket?
    Nov 2015
    Olive branch, MS
    Here is the area around the fuel injectors. What is this stuff??
  18. #18 Re: Lim gasket?
    looks like your lim bolts are all leaking coolant.
  19. #19 Re: Lim gasket?
    Nov 2015
    Olive branch, MS
    So I should probably go ahead and order all the gaskets?
  20. #20 Re: Lim gasket?
    The question is why haven't you already lol
  1. Head gasket problem, 25 miles on new gasket
    By GTPlzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2014, 04:25 PM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
