Thread: Check valve / pressure regulator to tune boost bypass actuator/solenoid?
Results 1 to 9 of 9
  1. #1 Re: Check valve / pressure regulator to tune boost bypass actuator/solenoid?
    what about not touching it?
  2. #2 Re: Check valve / pressure regulator to tune boost bypass actuator/solenoid?
    Mar 2015
    Connecticut
    (In before lewd jokes)
  3. #3 Re: Check valve / pressure regulator to tune boost bypass actuator/solenoid?
    Mar 2015
    Connecticut
    Questions:
    - Did I describe the operation of the boost control actuator and solenoid correctly? It that basically how the system works?
    - Is it possible under some load conditions for the vacuum line from the lower intake manifold to provide BOOST through the solenoid, pushing the actuator toward opening the bypass valve? Perhaps more so with a smaller pulley?
    Regardless whether or not I "touch it" I'd like to understand the system better.
  4. #4 Re: Check valve / pressure regulator to tune boost bypass actuator/solenoid?
    Apr 2011
    Lilburn, GA
    Along these same lines, can the operating parameters of the BCS be tuned in the ECM? Maybe to tune launch characteristics?
  1. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  2. Need help!~ with bypass valve boost actuator
    By dreama in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 09:22 AM
  3. boost bypass valve solenoid wiring
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2011, 09:59 PM
  4. how do i check my boost bypass valve?
    By bluevet03 in forum General Tech Discussion
    Last Post: 04-26-2010, 01:30 PM
