Thread: Loud "Whooshing" sound
Results 1 to 15 of 15
  1. #1 Loud "Whooshing" sound
    Aug 2016
    Vallejo,CA
    HELP! I'mbrand new to the forum and I see a lot of intelligent folks are here so I hope you can bail me out. I have a 1997 GTP. I had the infamous upper and lower intake gasket leaks and didn't catch it soon enough so I also had head gasket issues. I replaced the head gaskets and both upper and lower intake gaskets. Now that it's all back together, I have a loud "whooshing sound all the time. I've renewed the supercharger oil and that didn't help. I have removed the belts and the sound is still there and about the same volume. I've cheked and rechecked all my vacuum lines and even replaced the exhaust crossover donut and rear exhaust manifold to exhaust system studs and gasket. Nothing has changed the sound. Any suggestions?
  2. #2 Re: Loud "Whooshing" sound
    Kemmerer, Wyoming
    maybe it's the sound of the supercharger pushing air?
  3. #3 Re: Loud "Whooshing" sound
    post a vid of this in action. no idea with out seeing and hearing it.
  4. #4 Re: Loud "Whooshing" sound
    Aug 2016
    Vallejo,CA
    It makes the sound even with the supercharger belt off
  5. #5 Re: Loud "Whooshing" sound
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Air in the radiator? Sorry, "cooling system"?
  6. #6 Re: Loud "Whooshing" sound
    Aug 2016
    Vallejo,CA
    will do as soon as I get home
  7. #7 Re: Loud "Whooshing" sound
    Aug 2016
    Vallejo,CA
    could it make the sound even if the water pump is not spinning? It is a constant sound with or without any belts attached
  8. #8 Re: Loud "Whooshing" sound
    with out hearing it running, any advice is nothing more then a blind guess.
    both belts off does eliminate the front of the engine.
  9. #9 Re: Loud "Whooshing" sound
    Aug 2016
    Vallejo,CA
    I agree. It sounds like the noise is coming from the rear (driver's side) of the engine by the throttle body and rear exhaust manifold. I've checked the air box and actually took it apart and reseated it and that got me nowhere.
  10. #10 Re: Loud "Whooshing" sound
    Kemmerer, Wyoming
    sounds like it could be the egr. might be an exhaust leak, in which case, you should be able to feel air coming out of the leak location, or it could be a vacuum leak, and spraying starting fluid at the area where the leak is will change the sound of the idle for a brief time.
    like scott said, all we are doing is guessing.
  11. #11 Re: Loud "Whooshing" sound
    Aug 2016
    Vallejo,CA
    Quote Originally Posted by SgtMarshal View Post
    I agree that you're only guessing and I do appreciate the fact that you're willing to give me some input. One thing that I didn't mention and I'm not sure it matters but when I start it even with the belts off the supercharger is still spinning and it's spinning hard enough that it is hard to stop even holding the pulley with a belt.
  12. #12 Re: Loud "Whooshing" sound
    sc spins belt off, its sucking air past it so it can run.
  13. #13 Re: Loud "Whooshing" sound
    May 2016
    MN
    BBV all hooked up?
  14. #14 Re: Loud "Whooshing" sound
    Quincy, Mass
    Unplug the maf see if it's still doing it. Could be a bad maf or even a bad IAC, sounds to me like the intake is sucking in more air than usual. Mine will do it when I first start the car and then settle down after a min or 2. Could be a vacuum leak as mentioned above, I use rtv instead of throttle body and supercharger gaskets to prevent leaks.
    No more GP 04 Impala SS Indy:
  15. #15 Re: Loud "Whooshing" sound
    Aug 2016
    Vallejo,CA
    Got it! Thanks for directing me toward the egr valve. The flex pipe had a crack in it. Replaced and noise is gone.
  1. FIXED: "Flutter" sound only under boost. Ideas? - 2006 Grand Prix GT
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2015, 07:40 PM
  2. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  3. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  4. "clunk" sound on acceleration
    By DarkPassNger in forum Brakes/Suspension/Chassis
    Last Post: 07-25-2010, 01:09 PM
  5. Loud "Pop sound in rear 10 seconds after car is off
    By MidnightSpecial in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2009, 07:00 AM
