Thread: Loosing boost thinking vaccum leak.?
Results 1 to 8 of 8
  1. #1 Loosing boost thinking vaccum leak.?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys currently ive been having some problems it started off as my mpg went from 17 to about 14 for no apparent reason. I did get a check engine light for the upstream o2 sensor having a slow response but then the light went out on its own. While i was trying to figure out the bad mpg problem i started notice some occasional idle surges by about 500rpm while in park and also i was putting out about 6.5lbs of boost with my top swap on a stock pulley and when i tested it right now via torque pro i peaked at 5. Any thoughts?
    Sent from my LG-H811 using Tapatalk
  2. #2 Re: Loosing boost thinking vaccum leak.?
    Kemmerer, Wyoming
    check your LTFT's, if you have a vacuum leak, they will be highly positive like 16.4
  3. #3 Re: Loosing boost thinking vaccum leak.?
    hangover park IL
    Change the Upstream oxygen sensor
    ~James~ Psychotic Gearhead
  4. #4 Re: Loosing boost thinking vaccum leak.?
    Oct 2015
    Like 16.4 at idle? Cause i tuned my fuel trims and they lock in pretty on point
  5. #5 Re: Loosing boost thinking vaccum leak.?
    Oct 2015
    Quote Originally Posted by Turbocharged400sbc View Post
    Could the o2 sensor be causing my low boost? I checked all my vac lines and there all new and none are leaking some im confused
  6. #6 Re: Loosing boost thinking vaccum leak.?
    Oct 2015
    Status update i was logging some data using torque pro and noticed im now getting 3 degrees of kr when before i had none. And also my fuel trims are both locking in at 0 as if they have not learned yet although i have not reset my trims or taken out the battery anytime recently
  7. #7 Re: Loosing boost thinking vaccum leak.?
    Oct 2015
    Anything guys?
  8. #8 Re: Loosing boost thinking vaccum leak.?
    Nope.
  1. boost leak/ vac leak
    By NinetyEightGTP in forum General Grand Prix Discussion
    Last Post: 10-25-2013, 06:15 AM
  2. small vacuum or boost leak help
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2012, 02:09 PM
  3. boost leak
    By fremmy182 in forum General Tech Discussion
    Last Post: 10-24-2011, 09:01 AM
  4. boost bypass valve? vaccum line?
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 10:46 AM
  5. Huge vaccum leak at the PCV tee...
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2008, 04:27 PM
