Thread: small vacuum or boost leak help
Results 1 to 11 of 11
  1. #1 small vacuum or boost leak help
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    I've been hearing this small whistling noise (kinda like a turbo sound)in my car and it only happens sometimes when i drive my car mostly in the morning when its cool. Its noticeable around 3500 rpm's to wot. i dont feel that it affects my car on power or acceleration. I was thinking that it might be the boost bypass valve because ive heard of people saying that they can stay open. but im not sure and was just throwing it out there to see if anyone has had the same problem.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: small vacuum or boost leak help
    Apr 2009
    Maine
    My car was doing almost exactly as you described just recently. It was only making noise during boost. I don't recall that it went away after the car warmed up though. It turned out to be a leaky supercharger gasket. As you said, at first I didn't notice any problems, but it soon turned into a very noticeable misfire.
    To check for this, get some carb cleaner and spray it all around the edges of the supercharger while idling. If there's a leak, you should be able to see where some of the fluid got sucked in. The idle may go up or down as well.
    As a side note, if your BBV was stuck open, I would think you would notice a significant loss of power at WOT.
  3. #3 Re: small vacuum or boost leak help
    Sep 2011
    palm harbor florida
    Thats really funny because i have an ses light that wont go away for misfire. Thats what i thought about the bbv too but i was just throwing it out there. but thank you
  4. #4 Re: small vacuum or boost leak help
    Why don't people list codes etc when they ask for help on a problem?
  5. #5 Re: small vacuum or boost leak help
    Sep 2011
    palm harbor florida
    I was not referring my problem to the ses light it was to the leaky sound. the ses light just got thrown in there as this may be a solution to my problem thats all.
  6. #6 Re: small vacuum or boost leak help
    Pennsylvania
    Quote Originally Posted by Doug 97 gtp View Post
    As I've read Bill say many times, fix the known issues before tackling new, mystery issues.
    Sport Edition Kv5 18x8
  7. #7 Re: small vacuum or boost leak help
    The whole reason for asking why you didn't mention it. Often I find that cars toss SES lights to suggest there is an issue. Hearing an issue may be a secondary symptom of said issue.
    Fribo.. ax the mystery part on that. There aren't any mysteries, only learning experiences.
  8. #8 Re: small vacuum or boost leak help
    Sep 2011
    palm harbor florida
    i have tried i have replaced every single ignition part on my car and it was still there i checked all of the injectors for any bad grounds or crimped wired i found nothing either way im going to need to replace the gasket so if it knocks out the ses light as well as the leak then so be it ill be happy
  9. #9 Re: small vacuum or boost leak help
    Quincy, Mass
    a misfire can happen because of air, fuel, and spark. find which one isnt working right and youll fix your misfire.
    No more GP 04 Impala SS Indy:
  10. #10 Re: small vacuum or boost leak help
    Apr 2009
    Fort Worth TX
    Problem posts without SES and DTC info? Looks like one for the Rant forum.
    This is more than just a pet peeve for most of us here trying to help people. I'll leave it at that.
  11. #11 Re: small vacuum or boost leak help
    Sep 2011
    palm harbor florida
    Ive asked about thew misfire code before and everyone said to do your plugs. my plugs aren't the issue or my wires or my coils or my ICM. also i have no funds to fix my car. so how can i get rid of a light that is a muliple cylinder misfire. i know the code its a p0300 obd2 code. where was everyone when i asked about my ses light
  1. small vacuum line
    By rodman918 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2011, 04:23 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. 2002 GP GT 3.8L Small Vacuum Line Connected to Brake Booster Fitting At Upper Intake
    By LoveMyGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2010, 07:51 PM
  4. Small oil leak
    By Storm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2010, 08:55 AM
  5. Could a small valve cover leak cause a loss of boost on a PCV equipped vehicle?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 11:57 AM
