Thread: Air Leak on supercharger
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
  1. #1 Air Leak on supercharger
    Jun 2016
    Edmonton
    I have a air leak coming off the supercharger by where the throttle body mounts to the supercharger there is a hole on the housing on the bottom is this a problem or is this normal? It's a 2001 Gtp I've been leaking a little coolant don't know where and have a throttle body spacer on for the sound
    Thanks
  2. #2 Re: Air Leak on supercharger
    Kemmerer, Wyoming
    Is it on the back side next to the pcv valve in the bottom?
  3. #3 Re: Air Leak on supercharger
    Jun 2016
    Edmonton
    In the front by the coolant t stat
  4. #4 Re: Air Leak on supercharger
    Jun 2016
    Edmonton
    It's a factory hole by the base next to a bolt that holds down the supercharger
  5. #5 Re: Air Leak on supercharger
    post a pic.
    get rid of the spacer, they cause coolant leaks at the tb to blower. and they do nothing. other then leak.
  6. #6 Re: Air Leak on supercharger
    Jun 2016
    Edmonton
    deleted pic sending smaller one
    Air Leak on supercharger Attached Images
  7. #7 Re: Air Leak on supercharger
    Jun 2016
    Edmonton
    cant post another pic say i exceeded my amount hope this helps
  8. #8 Re: Air Leak on supercharger
    no idea what im looking at. host your pics on photo bucket, facebook or other site. then link pic here. pc to the site dont work well at all, as you just found out.
  9. #9 Re: Air Leak on supercharger
    Jun 2016
    Edmonton
    thanks i will try
  10. #10 Re: Air Leak on supercharger
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    post a pic.
    good advice right here. fix your air leak and coolant leak in one shot
    Sent from my SM-G930V using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  11. #11 Re: Air Leak on supercharger
    Jun 2016
    Edmonton
  12. #12 Re: Air Leak on supercharger
    We’re sorry, but your Gmail account is temporarily unavailable. We apologize for the inconvenience and suggest trying again in a few minutes. You can view the Apps Status Dashboard for the current status of the service.
    Go here sign up for a free account upload pictures there copy link here.
  13. #13 Re: Air Leak on supercharger
    Quincy, Mass
    The throttle body spacer is definitely you're problem, they are prone to leaking. And they do nothing good for your motor.
    No more GP 04 Impala SS Indy:
  14. #14 Re: Air Leak on supercharger
  15. #15 Re: Air Leak on supercharger
    Jun 2016
    Edmonton
    hope this helps. I'm going to pull the spacer off and see if the leak stops
    Thanks its behing the Eaton bypass valve
  16. #16 Re: Air Leak on supercharger
  17. #17 Re: Air Leak on supercharger
    still dont see a hole.
  18. #18 Re: Air Leak on supercharger
    Jun 2016
    Edmonton
    She was the spacer you can see the coolant all over the spacer
    sorry the pictures never worked out
    thanks
  19. #19 Re: Air Leak on supercharger
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I had one of those Taylor spacers on my car when it was N/A cost me about a hundred bucks. The coolant seeped through the gasket too. Biggest waste of money ever didn't even notice a difference. I'd take it off like Scotty said. I ended up selling it on ebay for like 20 bucks.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  20. #20 Re: Air Leak on supercharger
    Oct 2014
    portland oregon
    Are you referring to the hole that is between the vac line and wire harness? If so thats one of the 3 bolt holes for the TB to mount to the SC. Thats the only thing i can see in your pic that resembles a hole
  1. Air leak between supercharger and intake
    By markpa in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2014, 02:22 PM
  2. Replies: 10
    Last Post: 11-15-2013, 10:55 AM
  3. Supercharger leak
    By nvrstsfd23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2013, 11:46 PM
  4. Supercharger leak and PSI problem
    By BullittGP1998 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 02:01 PM
  5. Coolant leak below supercharger
    By dlemmen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2009, 01:15 PM
