Thread: Air leak between supercharger and intake
Results 1 to 3 of 3
  1. #1 Air leak between supercharger and intake
    GTP Level Member
    Oct 2014
    Not sure there is such a thing. But after flushing and filling antifreeze and hosing off the engine. The water in one of the valleys was bubbling. Not sure if it was an air leak some where or boiling. Neither seemed good. No real noise with it or after the water was gone.
  2. #2 Re: Air leak between supercharger and intake
    Mercer, Pa
    At idle the manifold is under vacuum and would suck the water in if there was a leak. If you saw bubbles it was boiling.
  3. #3 Re: Air leak between supercharger and intake
    GTP Level Member
    Oct 2014
    That makes sense. Just never owned one with a supercharger before and just picked this up. Giving it the once over. Man does that supercharger oil smell when you suck it out.
    Thanks
  1. Supercharger leak
    By nvrstsfd23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2013, 11:46 PM
  2. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  3. Intake Coolant Leak
    By rocketshipete in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2010, 07:16 PM
  4. Supercharger leak and PSI problem
    By BullittGP1998 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 02:01 PM
  5. Coolant leak below supercharger
    By dlemmen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2009, 01:15 PM
