Thread: VATS after engine swap
Results 1 to 2 of 2
  1. #1 VATS after engine swap
    Apr 2016
    Dalton, GA
    I put a SC 3.8 into an SE along with engine wire harness and computer, will I need to just do a key relearn or swap the ignition cylinder over to the SE so the computer and key match.
  2. #2 Re: VATS after engine swap
    you will, cause your changing the pcm to a new one.
    if getting a canned tune its a quick simple key on for 10 seconds and off, then it will crank. stock security learn is key to run for 10 minutes 3 times if your just swapping the pcm from another car.
  1. Help!! VATS issue
    By smws6ta in forum General Tech Discussion
    Last Post: 05-29-2015, 01:26 PM
  2. Replies: 3
    Last Post: 09-16-2013, 11:03 AM
  3. Not sure if I disabled my vats or not
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2013, 11:37 PM
  4. PassLock/VATS security system
    By eskimann in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2012, 06:58 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
