Thread: PassLock/VATS security system
Results 1 to 5 of 5
eskimann PassLock/VATS security system 11-30-2012, 09:52 PM
KeithGTP03 Re: PassLock/VATS security... 12-01-2012, 04:01 AM
eskimann Re: PassLock/VATS security... 12-01-2012, 09:18 AM
KeithGTP03 Re: PassLock/VATS security... 12-02-2012, 12:27 AM
eskimann Re: PassLock/VATS security... 12-11-2012, 06:58 PM
  1. #1 PassLock/VATS security system
    SE Level Member eskimann's Avatar
    canada
    Hi all. 03 GP GT- Is there any way to disable this system? Nothing but grief! Tx.
  2. #2 Re: PassLock/VATS security system
    Houston
    No. Why?
  3. #3 Re: PassLock/VATS security system
    canada
    Flashing security light. Had 2 non GM garages hook up with hand held computer. Have tried resetting. Neither could figure it out. Could be ignition or security module. Too expensive to take it to GM. Now, how do you know it can't be disabled? Tx.
  4. #4 Re: PassLock/VATS security system
    Houston
    Because you'd need a BCM that wasn't programmed to look for the correct resistance. And those don't exist. If everything is working normally, besides the blinking light, just remove the bulb for the security light and call it a day.
  5. #5 Re: PassLock/VATS security system
    canada
    Update.
    Was able to find a high end car audio shop to install one of these & completely disable the system. $135
    IDATALINK - UNIVERSAL TRANSPONDER BYPASS - ADS-TB | Staub Electronics Ltd.
  1. type of passlock/ security in a 2004 grand prix?
    By zvanaernum in forum General Tech Discussion
    Last Post: 01-23-2013, 10:07 PM
  2. Need help on a new security system to get
    By hockeybawler in forum Audio, Security & Visual Electronics
    Last Post: 07-16-2012, 10:46 PM
  3. Security system out
    By 03GPScottyd in forum Audio, Security & Visual Electronics
    Last Post: 10-11-2011, 12:15 AM
  4. security system question
    By bkatrenak in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2011, 05:37 PM
  5. Security system
    By musiknjoyr in forum Audio, Security & Visual Electronics
    Last Post: 12-09-2009, 10:43 AM
