Thread: Not sure if I disabled my vats or not
Results 1 to 13 of 13
  1. #1 Not sure if I disabled my vats or not
    Aug 2013
    Kitimat, B.C.
    I just swapped a 2002 3800sc from a regal into my 86 fiero convertible. I disabled codes P1626 and p1629-p1631 and changed it from serial to PWM. The car still starts for a second then dies, it will run like Shiite on starting fluid. Now I have codes
    p0452, p0463 and p1189. I read that the regal PCM vats can't be disabled in the tune, any truth to that?
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Not sure if I disabled my vats or not
    Florida
    Not sure if that is true, but are there any other bins you can run? I mean it is still a 3800. Maybe it's harness is a bit diff. I that the case you could just swap to a diff harness and hen switch to a diff bin where you can disable vats.
  3. #3 Re: Not sure if I disabled my vats or not
    Aug 2013
    Kitimat, B.C.
    The way I have it wired up, it works with 98-02 pcm's. I really DON'T want to have to rewire this, it's a biotch. I'm not sure about different bins, I hope that with hpt I could load a 2000 gtp file over the regal file and be done with it.
  4. #4 Re: Not sure if I disabled my vats or not
    Set injector disable time to 0 from 4
    Killing the codes only keeps them from reporting. Finding the checksum and flash crap and security in the other areas also does little. disable time is where it's at
  5. #5 Re: Not sure if I disabled my vats or not
    Aug 2013
    Kitimat, B.C.
    Pk where is that located in hpt? I seen it in the gear and differential abuse.
  6. #6 Re: Not sure if I disabled my vats or not
    Taht's in DHP, I don't think we can actually disable security in HPT
  7. #7 Re: Not sure if I disabled my vats or not
    Aug 2013
    Kitimat, B.C.
    Paw damn you got me exited for a moment. I was told that with the regal's, they have an anti theft system that can't be disabled. Any truth to that? Also if that's the truth, can I just take a gtp file and write it over top in the PCM?
  8. #8 Re: Not sure if I disabled my vats or not
    Aug 2013
    Kitimat, B.C.
    Hpt support told me that in a status bits log that I sent them that it shows that the vats are ok, but I don't understand that if it says it's ok, wouldn't that mean that it's still enabled and therefore will not start?
  9. #9 Re: Not sure if I disabled my vats or not
    Aug 2013
    Kitimat, B.C.
    I just checked and yeah I have spark and it'll run on starting fluid. I also back probed the injectors and there's power to both wires with KOEO intill it's cranked over then they ground out. I used the power probe III and it went from a positive battery voltage to a negative 0.0.
  10. #10 Re: Not sure if I disabled my vats or not
    Aug 2013
    Kitimat, B.C.
    Anyone? I just checked and while cranking both wires on the injectors ground out. I know the non pink wire will ground out but I assumed the pink would stay hot all the time.
  11. #11 Re: Not sure if I disabled my vats or not
    So the 02 wouldn't have vats, it would have passkey 2 or 3. I think 3. Which gives it a chip to excite in the tumbler. Vats is a simple resistor add on to the theft deterrent module. I'm pretty sure you can find into on what signal the pcm wants and bypass it. Heck the swap guys use a monte harness etc, maybe because theft is easier?
  12. #12 Re: Not sure if I disabled my vats or not
    Aug 2013
    Kitimat, B.C.
    Yeah I'm waiting on a 2000 gtp PCM to arrive, from what I've read it's easier to do that than piss with the regal vats.
  13. #13 Re: Not sure if I disabled my vats or not
    Aug 2013
    Kitimat, B.C.
    Well no luck with the wreckers, turns out they didn't have one after all so I just loaded a tune from a 2000 gtp and vroom vroom
  1. Remote Start Disabled
    By GXPrunner06 in forum General Tech Discussion
    Last Post: 07-25-2014, 10:58 PM
  2. Replies: 1
    Last Post: 02-01-2013, 05:52 PM
  3. Remote Start Disabled
    By stealthee in forum 04+ Specifics
    Last Post: 01-05-2013, 04:24 PM
  4. PassLock/VATS security system
    By eskimann in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2012, 06:58 PM
  5. disabled due to throttle control
    By cclan64 in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2012, 12:17 PM
