Thread: Negative LTFT, Knock Retard advice.
Results 1 to 11 of 11
  1. #1 Negative LTFT, Knock Retard advice.
    Apr 2016
    Saint Paul, MN
    Hello everyone I had a couple issues with my l67 upon fixing them other things are popping up and I'm looking for experienced advice.
    So car is a 98 GT Coupe(stock L36) that i top swapped.
    Exhaust (Manifolds crossover and DP) is all stock except u-bend delete.
    Ported gen 3 M90, and ported LIM, running stock 3.8 pulley. CAI, 180* thermostat, autolite 103's, and ZZP 1.0 PCM tuned for 91 octane but running 93. Approximately 3k miles on top swap.
    It started a couple days ago. Car ran exceptional decide I'm gonna go to the track for some fun. Figure it would be best to scan and make sure everything is in order. Everything looked good no knock, car pulls hard then i notice my LTFT lingering around +16%. Grabbed some carb cleaner thinking i had a vacuum leak, found 3. a leaking hose on SC tree, leak at PCV and EGR. sealed them all up no more leaks. However now my LTFT are inbetween -16% to -26% at idle, cruise, or decelleration.
    During acceleration under load the fuel trims even out to acceptable numbers but as soon as i let off throttle they go back to high negatives. Peaking around through torque scan i noticed during idle if i blip the throttle a little bit I'm getting random misfires upon revs dropping to normal. According to torque scan all my cylinders occasionally misfire with #'s 4 and 5 being the worse. Pulled all the plugs and they all look the same a bit white probably from running lean with leaks for however long but not bad.
    Reinstalled plugs. decided to throw in another FPR i knew was good i had laying around because i smelled faint gas in the vacuum hose. Unplugged battery for a few hours to reset fuel trims and took her for a spin. Feels good but LTFT are still chilling around -20% and i noticed 2 degrees of knock during a 2-3 shift at WOT. So i park to check things out. I'm still getting occasional current misfires in all cylinders but 0 under history not enough to trigger CEL apparently. But i can feel the surge and shake from the mis at idle. I snapped the throttle under frustration to hear that sweet SC whine and i noticed my scangauge read 7.3 degrees KR. Another thing i just noticed is slight gas smell in oil i will do a change asap.
    So to reiterate car ran good with vacuum leaks aside from high + LTFT. no knock under any condition. Not sure about the misfires though. After fixing vacuum leaks it would appear im running too rich and its causing me to knock like a mo fo.
    MAF, MAP, TPS, IAC, and ECT sensors are relatively new and showing correct values. O2 sensor was replaced 10k ago and I'm not sure of normal operating specs for that.
    I do hear an occasion tick or click from DP/CAT area at idle. Anyone have experience with ZZP PCMs? Do they tune them on the richer side causing my LTFT to be high negatives? Do all engines have occasional misfires? Is it something i shouldn't worry about until it triggers a CEL?
    also i thought KR was more prone to happen when running lean. How come i had no knock with vacuum leaks causing lean condition. But after fixing leaks and now running rich i have knock?
    Any ideas? I don't know where to go from here besides making vacuum leaks to even out trims.
    Also does anyone know if an exhaust leak before upstream O2 would cause a lean condition (high ltft) or a rich condition (low ltft)? this may be my problem though the leak would be small because it's not that loud.
    Any advice or info is appreciated. Educate me!
  2. #2 Re: Negative LTFT, Knock Retard advice.
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    which so cold of a range of plug? you don't have enough mods for that cold of a plug.
  3. #3 Re: Negative LTFT, Knock Retard advice.
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Yes an exhaust leak before the upstream o2 can cause problems. Do you have AFR scan gauge? I have a top swapped/cammed grand prix with a zzp tune without any issues. But why would you run stock manifolds? The front manifold is so restrictive that's the first mod I did N/A on my car is put a front zzp powerlog on is the least you could do or get headers.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  4. #4 Re: Negative LTFT, Knock Retard advice.
    Apr 2016
    Saint Paul, MN
    Yeah, i thought headers to be a required mod then saw that gtp's have the same exact headers stock and they even have the u-bend stock so i thought the hell with it and try an experiment with ported sc and lim with u-bend delete on 9:4:1 compression and see if i get knock. Which i didn't see any until i fixed vacuum leaks.
    I am going to get SD headers just didn't think i needed them at first.
    I used AL103's because i thought i could use all the help i could get in keeping things cool. May sound like foolish knowledge but i am a noob and learning as i go.
    Just read another thread that describes my misfire at idle and negative fuel trims to a T. It ended up being he replaced all the injectors and that solved his problem.
    So tomorrow morning I'll remove the injectors clean them and check for abnormal spray patterns. Switch out any that are finicky. Change oil, check fuel trims, and scan for knock. And report back tomorrow.
    And no i don't have a wideband that is the one thing i regret not getting before going into this. It appeared torque scan could read everything i needed until i realised i could only read commanded a/f ratio and not measured. I'll get one and install it when i do headers. Kill two birds with one stone.
  5. #5 Re: Negative LTFT, Knock Retard advice.
    Jul 2015
    Jamestown, NY
    What does the upstream o2 read during wot? ZZP claims that's an accurate enough reading for a/f that's what I go off of. Where did you get your injectors? Yea those stock manifolds are garbage the front one especially.
  6. #6 Re: Negative LTFT, Knock Retard advice.
    Apr 2016
    Saint Paul, MN
    I don't know off hand what they read at WOT i know at idle the upstream was reading .16v and the downstream was .18v I'll get the WOT numbers tomorrow. I have like 20 of the l67 injectors all got from junkers most likely one or more is not right. Hopefully i have some good ones in my pile.
  7. #7 Re: Negative LTFT, Knock Retard advice.
    Jul 2015
    Jamestown, NY
    The reading is only accurate at wot it should be mid to low 900's below 900mv and it's to lean
  8. #8 Re: Negative LTFT, Knock Retard advice.
    I agree on the spark plugs aswell, you really just don't need that cool of plug/ It's possible those are leading to the misfire.
    I'd switch them for some AL 605's as those are 1 heat range cooler than stock and really all you need on a basic top swapped motor.
  9. #9 Re: Negative LTFT, Knock Retard advice.
    Apr 2016
    Saint Paul, MN
    Alright time for an update.
    I switched out 5 of 6 injectors changed oil and removed battery for a few hours to reset trims.
    LTFT seems to be slightly better it peaked at -19% instead of -26% but only at idle or decelerating. Cruising or accelerating trims are perfect +/-5%.
    Didn't register any knock, even on some spirited runs up through 2nd.
    O2 sensor #1 reads .96v at WOT sensor #2 reads .95v at WOT.
    Still have some misfires at idle but instead of every cylinder being affected its only #3 and #5 now. Maybe it is the injectors and it just so happens most of mine are bad.
    I'll switch the plugs aswell just to rule that out as possible cause of the misfires and running rich.
  10. #10 Re: Negative LTFT, Knock Retard advice.
    Jul 2015
    Jamestown, NY
    I'd deffently run autolite 104's gapped at .050 that's what I run and most people they are one step colder I didn't realize you said you had autolite 103's. As far as the o2 sensor readings I don't know what those readings mean I use a aeroforce gauge the front o2 sensor is the only one that'll read the rear o2 is pointless it just registers if the front is reading I have a o2 emulator in it so I'll never have to buy a o2 again. Yea I would put some injectors in that you know are good zzp's are expensive but they are flow matched so every cylinder will get the same exact amount of fuel in my opinion is the best way to go.
  11. #11 Re: Negative LTFT, Knock Retard advice.
    Apr 2016
    Saint Paul, MN
    Thanks everyone for the advice and help.
    After scanning the past couple of days I've found that i have no knock and no misfires but LTFT still slowly climbs to -19% at idle. We'll see what happens when i install headers but my money is on the injectors. Guess i need to throw more mods at it so i have an excuse to get some 42# injectors.
  1. Negative LTFT from P0107/MAP?
    By Centauri in forum General Tech Discussion
    Last Post: 05-02-2015, 03:49 PM
  2. Negative LTFT and resettting trims.
    By industrialfish in forum General Tech Discussion
    Last Post: 01-18-2015, 10:07 PM
  3. knock retard
    By abrahamhuerta95 in forum Introductions/Noob Questions
    Last Post: 12-23-2014, 11:37 AM
  4. Knock Retard
    By Pontiac Grand Prix GT in forum Introductions/Noob Questions
    Last Post: 06-18-2013, 02:41 PM
  5. New Knock Retard
    By Bluemagic in forum General Tech Discussion
    Last Post: 09-19-2012, 09:22 AM
