Thread: Cylinder #1 Misfire, Please Help!!!
Results 1 to 3 of 3
  1. #1 Cylinder #1 Misfire, Please Help!!!
    Jul 2014
    Woodbine, KS
    I have an 06 supercharged 3.8. I keep getting a cylinder #1 misfire code. Here is what I have done so far: New spark plugs, new wires, replaced coil pack, replaced ignition module, replaced fuel injector, switched spark plugs/wires/coil packs around. I have tested compression and cylinder leakage with excellent results. I have sprayed brake parts cleaner all over the place and did no find any vacuum leaks. I have my scanner hooked up and on the misfire data screen: at idle no misfire, at 1500 rpm no misfire, at 2000 the misfires start showing on the scanner, and at 2500 rpm its shows a lot of misfire on the scanner. Then if I put it in gear and power brake it to 2500 rpm it shows no misfire on the scanner. I've tried everything I can think of to diagnose this misfire problem and if you have an idea or solution I'm all ears. Thanks in advance for your help
  2. #2 Re: Cylinder #1 Misfire, Please Help!!!
    Feb 2013
    37.295091, -121.930053
    what mods are you running? that would help big time
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Cylinder #1 Misfire, Please Help!!!
    Jul 2014
    Woodbine, KS
    Its all stock, just my daily driver.
  1. Misfire cylinder 4
    By RamairGTP2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2012, 06:17 AM
  2. Cylinder #2 misfire
    By EJOUIE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:38 PM
  3. cylinder one misfire
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2010, 03:48 PM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
