Thread: Missfire at high rpm or at shift...
Results 1 to 3 of 3
  1. #1 Missfire at high rpm or at shift...
    SE Level Member 98DaytonaGTP's Avatar
    May 2015
    United States
    I have a missfire at high rpm or at shift when I'm hard on the gas... At least it feels like it's cutting out at or around shift. Anybody know why?
    Stock tune, auto light 104s, speed daddy headers, 180 thermostat, stock supercharger pulley, ls7 lifters, cold air intake.
  2. #2 Re: Missfire at high rpm or at shift...
    I can only assume 91+ octane fuel aswell or atleast hope you are using it.
    Plugs are too cold for those mods, some AL 605's would be a better choice.
    And what gap are the plugs at?? I'd lower them to .050 if they are larger.
    Clean all coil pack terminals and use some electronic grease on them aswell, do all the little things to see if any of them do a fix.
  3. #3 Re: Missfire at high rpm or at shift...
    May 2015
    United States
    Ok IL try to lower the gap to .050 on the spark plugs and go from there.
  1. comp g guys, high shift rpms?
    By Reverant GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-28-2013, 02:07 AM
  2. High Idle and Shift Problem
    By joeysavoie in forum General Tech Discussion
    Last Post: 02-10-2013, 07:13 PM
  3. high RPM in 2nd, losing power in 3rd, weird shift into 4th
    By Jeremy Ashcraft in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2012, 08:40 PM
  4. won't shift to 3rd at high rpm
    By buthead in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-19-2010, 08:50 AM
  5. high rpm shift
    By DONDON3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2008, 08:46 AM
