Thread: Missfire under boost.
Results 1 to 20 of 20
  1. #1 Missfire under boost.
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    SO i got berta back today, the coolant leak was fixed but now whenever it goes into boost it starts missing.
    Heads were checked and re done during the last set of repairs so im guessing its ignition related. Only thing i can think is when the coolant sprayed everywhere the ignition coils got soaked, or i have a cracked spark plug.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Missfire under boost.
    double check the wires are on right. if they are, you should be getting a misfire code. check that plug.
  3. #3 Re: Missfire under boost.
    Sep 2014
    Richmond Virginia
    No code yet it runs just fine when its not in boost so the wires are fine
  4. #4 Re: Missfire under boost.
    double check em any ways. car can run pretty damn good with two wires crossed up.
  5. #5 Re: Missfire under boost.
    Sep 2014
    Richmond Virginia
    Wires are in place, on my way to class, on the interstate in rush hour traffic, it pretty much failed, any more than 5% throttle and misfire.
    Did set a code, Cyl 1 misfire. Not sure if its the plug wire or coil
  6. #6 Re: Missfire under boost.
    you know what to do now. at least the code popped and gave you a starting place.
  7. #7 Re: Missfire under boost.
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Hopefully chip didnt pay you a visit.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  8. #8 Re: Missfire under boost.
    Sep 2014
    Richmond Virginia
    The plug did not fix it, however the plug did not look broken so i dont think its chip. Especially since i had it apart a little while ago and it was clean only had 60 miles put on it since then.
  9. #9 Re: Missfire under boost.
    swap the plug wire with the one next to it, if its still missing on the same cylinder, swap a coil round.
  10. #10 Re: Missfire under boost.
    Sep 2014
    Richmond Virginia
    Odd, its much better after its been sitting, i can even go into light boost.
    one of the benefits of my dad working at a "bad credit" Used car place, Lots and lots of early 2000s GM parts. He has a bunch of coils I can have.
  11. #11 Re: Missfire under boost.
    Sep 2014
    Richmond Virginia
    No fix, it took more boost to make it miss, but i think thats because she was ice cold. Replaced the coil and the wire. Only thing left is the ignition module/platform
  12. #12 Re: Missfire under boost.
    you sure you didnt pinch the harness at the coil bracket? its grounded and all?
  13. #13 Re: Missfire under boost.
    Sep 2014
    Richmond Virginia
    I can double check, but its only on cylinder one, would a bad ground cause that?
  14. #14 Re: Missfire under boost.
    the icm harness ground. its a eye let on a black wire, gets bolted down to the side of the coil bracket.
    iirc you said you tore the engine down. just thinking of odd ball crap that can happen during re installation.
  15. #15 Re: Missfire under boost.
    Sep 2014
    Richmond Virginia
    Yeah my dad put it back together so im honestly not sure. Hes a master tech and works on 3800 all day so i doubt it, but im going to check regardless
    It was crunch time with the move so i let him take the lead
  16. #16 Re: Missfire under boost.
    those are two things that can happen to the best of us really if your not watching out. seen it happen here more then once. caught myself starting to pinching my own. its a tight area.
  17. #17 Re: Missfire under boost.
    Sep 2014
    Richmond Virginia
    No go, the harness is freely moving, and the ground loop is between a bolt and the bracket firmly tightened
  18. #18 Re: Missfire under boost.
    Donating Users
    Apr 2009
    Wheeling, WV
    Check to make sure the injector is plugged in firmly?
  19. #19 Re: Missfire under boost.
    GXP Level Member
    Mar 2015
    Tomball
    I would replace the companion cylinder plug and wire as well.
    Jeff
  20. #20 Re: Missfire under boost.
    Buffalo
    Is the plug seated correctly ? Gapped correctly ?
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. missfire under boost
    By blowngp3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 04:33 AM
  3. 98 GTP popping/missfire/backfire wile under any boost! HELP!
    By Bom Ber in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-29-2012, 01:06 AM
  4. HELP! Sputter Under Boost (feels like missfire)
    By OrangeL67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2011, 12:07 AM
  5. gtp missfire
    By mtz956 in forum General Tech Discussion
    Last Post: 12-24-2010, 10:58 AM
