Thread: gtp missfire
Results 1 to 7 of 7
  1. #1 gtp missfire
    SE Level Member mtz956's Avatar
    browntown
    my 98gtp missfire a little at full throttle like if gas cuts off . I got a fuel injector cleaner and my car got a bit better, but still missfires . Any suggestions? Thanks
  2. #2 Re: gtp missfire
    what's done to the car? what maintenance have you done or not done?
  3. #3 Re: gtp missfire
    browntown
    it has new sparkplugs autolite ,fuelfilter, tps and i cleaned the throttle body,maf and the idler control sensor. Need to do the sparkplug wire set.
  4. #4 Re: gtp missfire
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    if new wires doesnt fix it check coil resistance, if that doesnt fix it check your injectors
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: gtp missfire
    browntown
    im going to do the wire set, can bad coil resistance cause misfire? I have one that i got from junkyard it could be the one. I realy have bad wires hopfelly i can fix it. Misfire happens at high revs around 5000. Thanks.
  6. #6 Re: gtp missfire
    SE Level Member djs4021's Avatar
    Youngstown, Oho
    i chased something like this for a while. Might not be your issue but mine happened after a fresh tune up and turned out to be barely visible cracks in the porcelain on my new #4 plug. I think it was the result of not using a cushioned plug socket.
    01 Grand Prix GTP 8.8 MSD wires, K&N FIPK, ZZP Ceramic coated PLOG, ZZP 3'' Off-Road DP, Res Del, Borla Pro XS mufflers, Progress front sway, GMPP rear sway
    02 Bonneville SE with ZZP SSM90 kit. R.I.P
  7. #7 Re: gtp missfire
    browntown
    ok thanks going to check my plugs. And this happened after i got new autolite 106 plugs, before i was running ngk iridium car felt with more torque.
  1. missfire HELP!!
    By Will5600 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:25 PM
  2. missfire on cylnder 1 and 5
    By Rocket468 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:15 AM
  3. missfire under boost
    By blowngp3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 04:33 AM
  4. 04 GTP missfire
    By dlemmen in forum General Tech Discussion
    Last Post: 07-07-2010, 09:29 PM
  5. 01 GrandPrix GT random missfire?
    By Augustine in forum General Tech Discussion
    Last Post: 10-04-2009, 01:06 PM
