Thread: HELP! Sputter Under Boost (feels like missfire)
Results 1 to 20 of 30
  1. #1 HELP! Sputter Under Boost (feels like missfire)
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Okay so my car did this at high rpm's rarely,
    now it does this everytime I am in boost.
    I've been trying to find the problem and this is all the info I can offer about the ignition/ fuel system
    I have a 97 GTP. It starts up just fine
    It has a new racetronix fuel pump and filter
    New fuel rails
    New 65# injectors,
    New autolite 103 spark plugs gapped
    Checked out the coil packs and they seem fine
    New wires with no cracks
    Checked for vac leaks and there seem to be none.
    (-20 lbs of vac at idle)
    I'm stomped
    0.0 KR
    No misfires show up on the aeroforce gage???
    The car loses A LOT of power and sputters ( feels like misfires) when I accelerate hard or go into boost.
    Anyone run into this problem or have any suggestions? Please help a brother out.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  2. #2 Re: HELP! Sputter Under Boost (feels like missfire)
    Pull the plugs boss...check em. Also any CEL's?
  3. #3 Re: HELP! Sputter Under Boost (feels like missfire)
    SE Level Member GrandZero's Avatar
    ohio
    clean the mass air flow sensor then id check the plugs, could be some bad seals hows the viscosity of the oil?
  4. #4 Re: HELP! Sputter Under Boost (feels like missfire)
    Florida
    Start with the plugs...depending on age, you might be blowing the spark out since they could be worn. Recheck the gaps on them, and make sure they are wearing properly.
  5. #5 Re: HELP! Sputter Under Boost (feels like missfire)
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Quote Originally Posted by OrangeL67 View Post
    I have a 97 GTP.
    Doh!!!
    A sputtering / loss of power could feel like it is engine related when it is actually transmission related, any tranny problems lately???
    For all your 3800 needs:
  6. #6 Re: HELP! Sputter Under Boost (feels like missfire)
    Florida
    I was going to bring up trany too. Maybe tcc related.
    Maybe a clogged cat?
  7. #7 Re: HELP! Sputter Under Boost (feels like missfire)
    Nov 2009
    Michigan
    Thanks for all the suggestions.
    The plugs are new (changed them yeaterday trying to hunt down the problem) They are autolite 103's gapped at 52
    The trans is a TEP built less than a year ago
    And no CEL light pops up!!
    Car starts & rides perfect when I'm out of boost. The problem only occurs when I'm accelerating at about 50% throttle or more. (once I get into boost)
  8. #8 Re: HELP! Sputter Under Boost (feels like missfire)
    Nov 2009
    Michigan
    And also, I do not have a catalytic converter
    & I'm running Mobil 1 with about 2k miles on the oil
    Thanks for all the help guys, but I need more suggestions
  9. #9 Re: HELP! Sputter Under Boost (feels like missfire)
    Topeka, KS
    Have you hooked a scan tool upto your car? Your dash bulb could be burnt out. I'd want to hook one up if you haven't just to make sure there isn't any CEL's.
  10. #10 Re: HELP! Sputter Under Boost (feels like missfire)
    Orange County, NY
    it may be related to your tune.
  11. #11 Re: HELP! Sputter Under Boost (feels like missfire)
    Nov 2009
    Michigan
    Damn. Just cleaned the Maf. Still have the same problem. It looks like my bypass is doing some wierd stuff when I rev it. It likes to bounce open and closed? I can't figure this crap out
  12. #12 Re: HELP! Sputter Under Boost (feels like missfire)
    Feb 2008
    Video of the bypass? It should be open (up position) at idle and closed (down position) under boost or with the car off.
  13. #13 Re: HELP! Sputter Under Boost (feels like missfire)
    SE Level Member batman1988's Avatar
    Junction City, Kansas
    Is any black smoke coming out? I had the same problem but i had black smoke, i disconnected my MAF and punched it a few times and the problem was gone.
    04 ESCALADE ESV: Wife's DD
    98 Buick Regal GS: Stock
  14. #14 Re: HELP! Sputter Under Boost (feels like missfire)
    Nov 2009
    Michigan
    Quote Originally Posted by DanGTP View Post
    The BBV bounces when the car coughs. However, it does not do this much in neutural or park, so it's hard to get a vid. Usually the car hesitates while I'm in drive and get on it down the road
    Quote Originally Posted by batman1988 View Post
    No black smoke. The car literally drives perfect until I get it into boost. Thats when it studders like I'm revving out off the limiter, but the rpms will slowly bounce thier way up through the powerband.
  15. #15 Re: HELP! Sputter Under Boost (feels like missfire)
    Disconnect your MAF and go for a drive, build up boost a few times and see if it goes away. If that is not it, i would check for a vac leak. I could be wrong.
  16. #16 Re: HELP! Sputter Under Boost (feels like missfire)
    Florida
    That sounds just like what happened with mine when a coil pack went bad...
    It didnt blink and CELs like it should with a misfire...
    Go out tonight when it's dark, pop the hood, and rev the engine, and see if there are any sparks...
    its just a thought, and pretty easy to check too...Once i changed the coils out, the stuttering/misfire went away
  17. #17 Re: HELP! Sputter Under Boost (feels like missfire)
    Apr 2011
    Baltimore
    I had the same problem on my 98 gtp and there where multiple problems but your all looking in the wrong places. It is the knock sensors.
  18. #18 Re: HELP! Sputter Under Boost (feels like missfire)
    Feb 2008
    Didn't think about the knock sensors. Is there a diagnostics test for them? Or, does one just change them and hope it solves the problem?
  19. #19 Re: HELP! Sputter Under Boost (feels like missfire)
  20. #20 Re: HELP! Sputter Under Boost (feels like missfire)
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    my car is doing the exact same thing but i think i know why on mine check all out connectors especially the one in the back mine is broken and not sitting in all the way and i keep coming up with p1361
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  1. missfire under boost
    By blowngp3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 04:33 AM
  2. Acceleration sputter
    By X97prixX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-18-2010, 03:42 PM
  3. gtp start sputter
    By zildjian102 in forum General Tech Discussion
    Last Post: 10-09-2010, 11:08 AM
  4. Car starts to sputter between 2k and 2.5k rpms
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 11:24 AM
  5. bad sputter new guy
    By DIRTYDEVIL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2010, 04:15 PM
