Thread: Timing chain?
Results 1 to 16 of 16
  1. #1 Timing chain?
    Donating Users
    Apr 2009
    Wheeling, WV
    Hey guys....
    Is there a single row roller chain kit we can use that doesn't use a tensioner?
  2. #2 Re: Timing chain?
    May 2008
    Schuyler, NE
    Nope. And stay away from single row roller chains. Either use a factory chain, or switch to a double row.
  3. #3 Re: Timing chain?
    ^^That.
    And if you switch to a double roller...pray a lot.
    Because they're hit and miss.
  4. #4 Re: Timing chain?
    Donating Users
    Apr 2009
    Wheeling, WV
    Are there any better options than the stock dampener?
  5. #5 Re: Timing chain?
    Why do you need an upgraded chain and dampner?
    Many people run aftermarket cams with a new chain and dampner.
    Unless you're going with a cam larger than .550~ lift with some aggressive 130lb + valve spring...there is no need for a upgraded chain.
  6. #6 Re: Timing chain?
    Donating Users
    Apr 2009
    Wheeling, WV
    I'm planning on upgrading my springs with my 1.9 rockers, and I've heard bad things about the LS6 springs I'm planning on using with the stock dampner.
    But if you guys think I'll be ok, then I'm cool with that.
    BTW- the car only has 58k.. 01 GTP
  7. #7 Re: Timing chain?
    Yup new stock timing chain and new dampner you'll be fine even with ls6. Another option are the L76 from the g8. A bit easier on the dampener. Do some searching on here and I'm sure you'll find plenty of info.
    04 Comp G.
  8. #8 Re: Timing chain?
    Bastard Reptile's Avatar
    Kansas City, MO
    LS6 springs are good springs. I've got them, and I've never had an issue with them and a stock chain/damper combo.
  9. #9 Re: Timing chain?
    Kemmerer, Wyoming
    this is the first time I've heard someone say LS6 springs were problematic. GM has made and installed millions of sets in their engines with success. I would be curious if any other valve spring manufacturer could make the same claim.
  10. #10 Re: Timing chain?
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Quote Originally Posted by SgtMarshal View Post
    The yellow ones had issues.
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  11. #11 Re: Timing chain?
    Donating Users
    Apr 2009
    Wheeling, WV
    I should clarify.. I've heard bad things about the ls6 springs with stock dampners.
  12. #12 Re: Timing chain?
    Buffalo
    Quote Originally Posted by dcrews View Post
    we have aftermarket dampeners?
  13. #13 Re: Timing chain?
    Kemmerer, Wyoming
    the LS6 springs are a behive style spring, different than the 3800 springs, so the retainers need to be changed to the behive style
  14. #14 Re: Timing chain?
    SE Level Member l36grandprix's Avatar
    florida/ohio
    ZZP and ATI make them.
  15. #15 Re: Timing chain?
    Kemmerer, Wyoming
    Quote Originally Posted by l36grandprix View Post
    I think you are referring to harmonic balancers, which is different than a timing chain dampener.
  16. #16 Re: Timing chain?
    Kansas City, MO
    I've never...ever....one single time had an issue with the LS6 springs. Yellow or blue.
  1. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  2. 3.1 timing chain
    By bybeecl in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-01-2011, 11:56 AM
  3. timing Chain
    By Zach3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:12 PM
  4. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  5. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
