Thread: My build, missing anything? Suggestions?
Results 1 to 17 of 17
  1. #1 My build, missing anything? Suggestions?
    Jul 2014
    New Jersey
    I may add a double roller and ported heads, but this is what i have so far
    L67 block and rods
    L36 trans
    Vs camshaft
    Federal mogul hypereutectic pistons
    Hastings piston rings
    Rod bolts
    Camshaft bearing
    Rod bearing
    Main bearing
    Ls7 lifters
    7.05 pushrods
    90lb valve springs
    Ported throttle body
    Ported supercharger
    3.4 pulley
    Cold air intake
    Headers
    Alternator voltage booster
    Tuned pcm
    Shift kit
    New gaskets all around
    Lowering kit with new struts
    Oil pump and volume kit
  2. #2 Re: My build, missing anything? Suggestions?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Quote Originally Posted by xcwilli11 View Post
    L67 block and rods
    TEP trans
    IS3 camshaft
    Rod bolts
    Camshaft bearing
    Rod bearing
    Main bearing
    Ls7 lifters
    7.05 pushrods
    130lb valve springs
    Ported supercharger
    2.8 pulley
    Cold air intake
    Headers
    Tuned pcm
    Shift kit
    80# injectors/255 pump/ E85
    There, that seems like more payout for that effort.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  3. #3 Re: My build, missing anything? Suggestions?
    And hopefully alot of machine work aswell, you don't want a 10 minute motor.
  4. #4 Re: My build, missing anything? Suggestions?
    Jul 2014
    New Jersey
    Yeah, i forgot to mention that
    Hone cylinders
    Check crank
    Resurface head
    Etc
    Sent from my LG-D851 using Tapatalk
  5. #5 Re: My build, missing anything? Suggestions?
    Jul 2014
    New Jersey
    I'll have to look into some of those mods, i dont have e85 near me
  6. #6 Re: My build, missing anything? Suggestions?
    last 2 guys who did rebuilds, well it ran them 2500 to 3000 grand......i vote f the block rebuild. unless your willing to spend more on a engine then the cars worth. your call and wallet in the end.
  7. #7 Re: My build, missing anything? Suggestions?
    Quote Originally Posted by ScottyDoggs View Post
    This
    Grab a good JY motor. Regasket it. Pretty it up and never touch the bottom end and install go fast parts and not worry about spending $2k in machine work for a potential 10 min motor
    04 Comp G.
  8. #8 Re: My build, missing anything? Suggestions?
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    thought about porting the lower intake?
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  9. #9 Re: My build, missing anything? Suggestions?
    Jul 2014
    New Jersey
    Cant believe i forgot about the lower intake! Anyone have a link to a good how to porting thread?
  10. #10 Re: My build, missing anything? Suggestions?
    Kemmerer, Wyoming
    Check out my sale thread, I have some good stuff that will help your build make some good power
  11. #11 Re: My build, missing anything? Suggestions?
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    http://www.grandprixforums.net/threa...-Porting-Guide
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  12. #12 Re: My build, missing anything? Suggestions?
    Jul 2014
    New Jersey
    Thanks for the input all!
  13. #13 Re: My build, missing anything? Suggestions?
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Looks to be a budget build like mine. VS cam, 90 springs, intake, headers, and the rest stock. Use a JY block. I also ordered a TEP trans. A few things I ended up spending additional on..... Valve spring retainers since stock retainers on the LS6 90 springs results in wrong installed height. Reuse stock keepers. I also rebuilt the supercharger snout, new idler and tensioner pulleys, new motor and trans mount, TTY head bolts, reusable rocker arm bolts, new stock timing chain and tensioner. These little things add up but help improve reliability and might as well replace it while you are in there.
    I personally wouldn't rebuild a stock motor either. Poor return on investment. Run a junkyard lower block. I also wouldn't pay to port with such a mild cam unless you are doing it for free.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  14. #14 Re: My build, missing anything? Suggestions?
    Jul 2014
    New Jersey
    I'm good with trans work so i'm actually going to build mine up a little, you could call it a budget build or a reliable build i want power but not so much i **** things up
    i actually already have the springs and correct retainers and the others things you mentioned, only thing i might add is the snout rebuild
  15. #15 Re: My build, missing anything? Suggestions?
    Jul 2014
    Toledo, OH
    I have a press so it was about $50 for the seal, bearings, fluid, and coupler. Got it apart might as well do it and not worry. Good walk-through on YouTube. Only issue I had was one of the Torx snout bolts stripped so I had to drill, easy out, and replace. Took an extra 15 min. Whoop de do.
  16. #16 Re: My build, missing anything? Suggestions?
    Jul 2014
    New Jersey
    yeah i have a full sized press at work i would use, doesnt seem to bad to do and for 50 dollars its definitely worth it
  17. #17 Re: My build, missing anything? Suggestions?
    Machine work meaning: make sure the mains line up.
    That's the most important thing.
    Period.
  1. Replies: 399
    Last Post: 08-17-2016, 01:35 PM
  2. Build all you can build S/C 3800
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2013, 12:01 AM
  3. missing my gtp
    By john cola in forum General Grand Prix Discussion
    Last Post: 05-19-2013, 02:57 PM
  4. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  5. Do you see anything missing here?
    Last Post: 02-24-2009, 06:26 PM
