I'd start out like mentioned.
Check power/ground at connector and back up from there. 00 and 02 should be the same harness, fuses being good should be good. Likely you haven't gotten enough drive cycles to set codes, so that is out for help. When you had crispy wires..something should have popped a fuse somewhere.
