View Poll Results: What cam should i use
Voters
6. You may not vote on this poll
  • Wbody Stage 1
    0 0%
  • 3800 Stage one
    0 0%
  • zzp VS
    0 0%
  • zzp XP
    6 100.00%
Thread: What Cam Should i install
Results 21 to 40 of 41
  1. #1 Re: What Cam Should i install
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Is milling the guides all that needs to be done to the heads to run something like an xpz?
    I know I need like 130# springs and retainers and a double roller. (can the stock pushrods handle that?)
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: What Cam Should i install
    May 2008
    Schuyler, NE
    Yes, all you need to do is mill the guides. A port and polish is highly recommended, but sounds like you are getting that done.
    The xpz requires different pushrod lengths. Stock is fine strenth-wise, but they are not the correct lenghts.
  3. #3 Re: What Cam Should i install
    Sep 2014
    Richmond Virginia
    What about the s3? same lengths?
    Its starting to sound like I should wait on the cam until I have a good chunk of cash to throw at it, and just go e85 for now.
  4. #4 Re: What Cam Should i install
    Buffalo
    When you buy the xpz new or used it usually comes with the rods
    my s3 cam used 1 length
  5. #5 Re: What Cam Should i install
    *insert under analyzed post here about over analyzing cam choice*
  6. #6 Re: What Cam Should i install
    Buffalo
    Dude. I looked at s1x cam with a more lift using 1.8 or 1.9 rockers but same duration. Then I looked at the xpz vs s3. I considered a custom grind but I could what I found was if it could have been done it would have already. Soo many numbers being thrown around.
    Searched for days on actual s3 and xpz 1/4 miles and dyno charts.
  7. #7 Re: What Cam Should i install
    Sep 2014
    Richmond Virginia
    I think Im going to e85 first, if im going to bother with a cam I might as well go for the throat.
    I can e85 the thing for 500, a "Proper" cam install with a big boy is going to cost me closer to a thousand it looks like.
    cam, 330, lifters 100(my LS7 have metal in them) Rings 120, retainers 40, double roller and install parts 150, gaskets 100, misc head work ~50-200, tuner 260 depending what I get done.
    e85, Injectors 250, tuner 260
    ( I could just throw 42# and go too)
    I appreciate all the info!
  8. #8 Re: What Cam Should i install
    Kemmerer, Wyoming
    Quote Originally Posted by 04lss View Post
    did you mean to say "springs" when you said rings?
  9. #9 Re: What Cam Should i install
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by SgtMarshal View Post
    Yes
  10. #10 Re: What Cam Should i install
    Buffalo
    Wa wa wa waaaa
  11. #11 Re: What Cam Should i install
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by Crazyguy03 View Post
    Wa wa wa waaaa
    I realized I need twice the budget I have to Do it right.
  12. #12 Re: What Cam Should i install
    Buffalo
    Budgets. Sure as hell didn't buy mine in one shot. Buy used , shop around, collect and be patient...
    look for someone demodding and grab some 42s and see if you like the corn method
  13. #13 Re: What Cam Should i install
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    NIC Cam, they have minimal power, everyone hates them for some odd reason, but they sound tits, and I like tits.
    1999 Buick Regal "Betty White"
    NIC Cam FSIC E85 Built Trans Flaky Paint
    Ported Aluminum Coolant Elbows
  14. #14 Re: What Cam Should i install
    Buffalo
    Have you heard mine? Me likes
  15. #15 Re: What Cam Should i install
    Mar 2015
    Port Huron, MI
    Quote Originally Posted by CrazyGuy03 View Post
    No hahha have you heard mine? Wish I had a youtube link, hell I might just upload the vid right now!
  16. #16 Re: What Cam Should i install
    Buffalo
    Do it !
    i think I have both the s1x and the s3
  17. #17 Re: What Cam Should i install
    Mar 2015
    Port Huron, MI
    Do it !
    http://youtu.be/r5Wq3JuL4_8
  18. #18 Re: What Cam Should i install
    I miss my thrasher cam.
    It shook my fillings out.
  19. #19 Re: What Cam Should i install
    Buffalo
    Cheater! You got the cut out open. Well the I'll have to show you mine with open down pipe
    ****er didn't wanna run at the end lol
    http://youtu.be/Yk1G1sTOIm0
  20. #20 Re: What Cam Should i install
  1. Aux In Install GP +04
    By JohnnyTwoTimesTwoTimes in forum Audio, Security & Visual Electronics
    Last Post: 08-19-2014, 10:10 PM
  2. Xp Cam install
    By Juskenny7 in forum Northeast
    Last Post: 09-04-2013, 08:41 AM
  3. DP install
    By K Kraziee in forum General Tech Discussion
    Last Post: 05-24-2013, 09:49 PM
  4. EGR on or off after VS cam install
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 09-29-2012, 01:50 PM
  5. what do i need for hu install?
    By twol8uluz in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2012, 09:33 PM
