Thread: DP install
Results 1 to 20 of 21
K Kraziee DP install 05-17-2013, 08:29 PM
dsmuts Re: DP install 05-18-2013, 07:32 AM
K Kraziee Re: DP install 05-18-2013, 12:17 PM
dsmuts Re: DP install 05-18-2013, 12:35 PM
99prixgt Re: DP install 05-18-2013, 02:14 PM
K Kraziee Re: DP install 05-21-2013, 08:28 PM
dsmuts Re: DP install 05-22-2013, 05:53 AM
K Kraziee Re: DP install 05-22-2013, 07:34 AM
BillBoost37 Re: DP install 05-22-2013, 07:38 AM
K Kraziee Re: DP install 05-23-2013, 09:08 AM
BillBoost37 Re: DP install 05-23-2013, 09:33 AM
K Kraziee Re: DP install 05-23-2013, 10:23 AM
REDCRAPGP Re: DP install 05-23-2013, 12:09 PM
K Kraziee Re: DP install 05-23-2013, 01:18 PM
dsmuts Re: DP install 05-23-2013, 03:02 PM
REDCRAPGP Re: DP install 05-23-2013, 03:13 PM
K Kraziee Re: DP install 05-23-2013, 04:30 PM
smoke14 Re: DP install 05-23-2013, 05:14 PM
K Kraziee Re: DP install 05-23-2013, 08:52 PM
K Kraziee Re: DP install 05-24-2013, 07:51 PM
smoke14 Re: DP install 05-24-2013, 09:49 PM
  1. #1 DP install
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    So I just bought a ZZP 3" DP and I'm planning on installing it myself when it arrives. My question is, if the bolts are so rusted that there not reusable, what kind do I need to pick up? And what do I need if the studs are so rusted that there not reusable? Thanks
  2. #2 Re: DP install
    The bolts to the manifold should come off the ones to the exhaust usually need cut off and drilled out and new bolts used. I used bolts i had laying around the garage. Soak them in pb blaster everyday when the engine is cool until the day you do it. That should help
  3. #3 Re: DP install
    Apr 2013
    Milwaukee
    Ok thanks. Are the DP to exhaust bolts threaded?
  4. #4 Re: DP install
    Dp to catback is 2 nuts
  5. #5 Re: DP install
    Jersey
    hopefully there not as rusted as my 97 gtp was, I put enough torque on the bolt to bend and break the flange on the catback side
    16' wrx sti- stock
  6. #6 Re: DP install
    Apr 2013
    Milwaukee
    Ok so I have used PB on the bolts for the past few days, I will be installing my DP in the next couple days, I just want to make sure what kind of bolts they are since I haven't taken a good look at them since there's rust built up that I have to brush off. Are they a single bolt threaded right in or is it a bolt with a nut on the end?
  7. #7 Re: DP install
    Nuts either 13 or 15mm
  8. #8 Re: DP install
    Apr 2013
    Milwaukee
    Ok got it thanks.
  9. #9 Re: DP install
    I think they start out as 15's and rust their way down to 14's or 13's.
  10. #10 Re: DP install
    Apr 2013
    Milwaukee
    Well its defiantly a no go for me to do it. I dont have much room to manuver underneath and there rusted on there pretty good. If anyone could do it for me in the MKE area, I'll give em $75
  11. #11 Re: DP install
    Jack it up higher..
  12. #12 Re: DP install
    Apr 2013
    Milwaukee
    I put it on ramps I bought at menards and it was still way too low to get any good leverage on there. My jack didnt even go high enough on the front to jack it higher. And another problem is on the sides where the jack points are, is really rusted so I'm afraid of trying to jack it there because it might just bend or break apart.
  13. #13 Re: DP install
    What I do for example when I have to do something on the Silverado. I grab some tiles or cinder block etc and I place the cinder block underneath the jack so I can jack the truck up high enough to be able to put jack stands underneath it. Jack it up on the subframe and make sure that the cinder blocks are in a position where they don't move and then make sure the car is supported by jack stands and then lower the jack etc.
    04 Comp G.
  14. #14 Re: DP install
    Apr 2013
    Milwaukee
    Well idk if its possible from the front cuz it seems like it would have to be jacked really high in order to get decent leverage. If its fron the side, it seems like it might tip over lol so i think it would be 100 times easier on a lift. unless someone could give me an example.
  15. #15 Re: DP install
    I run mine up on ramps before and it's kinda tight. I usually use my jack to get it high enough to get them off.
  16. #16 Re: DP install
    The way I installed my headers was like this old fit a jack underneath the subframe because hellaflush. So instead of drive the car on 2 small tiles that I had in the yard. Have me enough height to slid the jack under the subframe. I jacked it as high as it could go. Then put jack stands underneath the subframe and removed the jack. Removed the dogbones.Then I unbolted the downpipe to resonator and the downpipe is now dangling slightly enough where I can slid a extensions and breaker bar enough to loosen the downpipe bolts.
    04 Comp G.
  17. #17 Re: DP install
    Apr 2013
    Milwaukee
    I'll try it again, I do have two jacks, so I might put one in front and one in back to see if that helps. Only thing is, I only have 2 jack stands.
  18. #18 Re: DP install
    Apr 2012
    Goderich, Ontario
    I drove the front of my car up onto ramps then jacked up the back of the car onto jack stands. I also had to get new bolts for the flange closest to the rez.
    -Paul Walker
  19. #19 Re: DP install
    Apr 2013
    Milwaukee
    Ya I tried it again and was able to get under there easier, but my nuts are shot lol they wouldnt budge after PB and a torch so they will probly have to be cut out. Pain in the ass
  20. #20 Re: DP install
    Apr 2013
    Milwaukee
    I had to take it in to get installed. The flange on the res was too rusted to use the bolt so he had to make a new flange for me. Defiantly a good mod to have tho. Much better response. Glad to have that U bend off.
  1. 04+ HUD Install
    By Explicit_Spade in forum 04+ Specifics
    Last Post: 03-02-2016, 11:03 PM
  2. HUD and DIC install
    By rell2005 in forum Audio, Security & Visual Electronics
    Last Post: 06-06-2011, 05:01 PM
  3. Need help after pcm install
    By Perry125 in forum PCM Tuning
    Last Post: 02-21-2010, 09:50 PM
  4. L36 LIM Install
    By 01gtspecial in forum General Tech Discussion
    Last Post: 07-08-2009, 10:29 AM
  5. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
