Thread: LIM gasket failure or old fluid sludge?
Results 1 to 8 of 8
  1. #1 LIM gasket failure or old fluid sludge?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I opened my radiator and found this :
    Is it old GM antifreeze that has sludged up or are my LIM gaskets going?
    I flushed the radiator recently but couldnt get the inside of the radiator clean.
    oil level seems fine
    LIM gasket failure or old fluid sludge? Attached Images
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: LIM gasket failure or old fluid sludge?
    oh the beauty of dex sludge. time to flush that crap out
    one you flush to water you can fill it with water and some prestone flush to help break up what even my be hanging out inside still.
    how to flush coolant.
    remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
    get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
    then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
    put your t stat back in, with new gasket, the upper hose back on.
    now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
    now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
    done.
  3. #3 Re: LIM gasket failure or old fluid sludge?
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by ScottyDoggs View Post
    done.
    I got a low coolant light, and it was definitely low on coolant, Im thinking the radiator is leaking, so i might just end up replacing it with an ebay radiator.
    and replacing the hoses at the same time.
  4. #4 Re: LIM gasket failure or old fluid sludge?
    Actually.. that looks a lot more like someone topped off a system of Dex with green. Flush...really well and smile.
  5. #5 Re: LIM gasket failure or old fluid sludge?
    dude cut your finger nails
  6. #6 Re: LIM gasket failure or old fluid sludge?
    Buffalo
    Looks like butt gravy when your fingernail pokes through the paper
  7. #7 Re: LIM gasket failure or old fluid sludge?
    Enfield, CT
    looks like there's some metallic flakes in that poopy fluid.
  8. #8 Re: LIM gasket failure or old fluid sludge?
    I'm BillBoost
    There...I played that card.
  1. LIM-FelPro gasket failure?
    By michael redmon in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-10-2015, 05:11 AM
  2. Worst Intake Gasket Failure Ever
    By TLSheff in forum General Grand Prix Discussion
    Last Post: 10-02-2014, 08:46 AM
  3. sludge in coolant
    By gobux in forum General Tech Discussion
    Last Post: 02-15-2013, 07:18 PM
  4. LIM replacement, sludge
    By The Chad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 01:52 PM
  5. TB Gasket Failure?
    By ChrisJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2010, 05:49 PM
