Thread: whats causing this coolant leak?
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 whats causing this coolant leak?
    Florida
    Today i look under my car on the driveway and see i lost a nice batch of coolant. Cant quite pinpoint exactly where its coming from but i see a couple of hanging drips right at the rear of thesubframe on passenger side like to the left and behind the Trans pan. My first thought was lower coolant elbow or heater core lines but idk. Any ideas?
  2. #2 Re: whats causing this coolant leak?
    SWPA
    Sounds like coolant elbow to me. Probably want to wipe everything off, then start the car and looking for leakage/seepage.
  3. #3 Re: whats causing this coolant leak?
    or the water pump.
    you can grab the pulley with 2 hands and rock it back and fourth, if it moves thats the leak.
  4. #4 Re: whats causing this coolant leak?
    Florida
    Well if it was the water pump wouldn't i have squeeky belt?
  5. #5 Re: whats causing this coolant leak?
    Florida
    I have somehwhat of an idea,i believe it may be the lower elbow. I have the car on ramps and went under,cant see the lower elbow but the leak is coming from somewhere next to and a lil above the oil filter area.
  6. #6 Re: whats causing this coolant leak?
    car off, you can stick your fingers in where the lower elbow meets the engine. just follow the heater hose tube down the alt bracket, follow it in. if its leaking it will be wet back there.
  7. #7 Re: whats causing this coolant leak?
    Florida
    Well checked all in there with the coolant res. out the way and its neither wp nor lower elbow. This is weird now.
  8. #8 Re: whats causing this coolant leak?
    Dec 2012
    Where 4T65E's were born
    I was having the same issue, WP and both elbows were dry, yet coolant was directly under that spot. I just let it leak until i wasn't allowed to park in the drive anymore..lol. Then took it to work and all of a sudden my upper coolant elbow started leaking and my boss was like, thats it right there. (even though it was bone dry when it was leaking before, so i had 2 coolant leaks then) We replace the elbows and I tell my parents we fixed a leak, there are still puddles on the driveway appearing, I'm assuming my car is still leaking. oh well, I'll look into it when the weather isn't so brutal. It doesn't always leak, just sometimes. Cannot find the source though.
    Sold.
  9. #9 Re: whats causing this coolant leak?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Check the two heater hoes that go into the tensioner. I replaced my sons tensioner for the 3rd time last weekend and he was still dripping coolant. One of the o-rings were seeping. Cheap easy fix. I did it in 20 degree weather while it was snowing in shorts .
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  10. #10 Re: whats causing this coolant leak?
    Sep 2011
    Canada
    Get the car up to operating temp. It might only leak when your thermostat is open. Get the car warmed up and the thermostat open then check for leaks. From the amount you're talking about it should be easy to find.
  11. #11 Re: whats causing this coolant leak?
    Florida
    Apparently its the wp weephole,mechanic checked it. But.this leak has a mind of its own. Barely anything now in 2 days although i did take stuff apart yesterday.
  12. #12 Re: whats causing this coolant leak?
    SE Level Member eshina17's Avatar
    Dec 2011
    Marquette, MI
    Quote Originally Posted by dmahlikGT View Post
    I had this same exact issue. Leaked a lot at times, and other times it didnt leak. Thought it was coolant elbows at first, so replaced with the better aluminum ones. Still had a leak after so I swapped out the water pump. The gasket was just destroyed. So that is most likely what youve got going on. Not too hard of a job, took me a few hours
    1987 Pontiac Fiero 2M4 - Sold
    2002 Dodge Stratus R/T - Piece of ****! - SOLD
    1997 Pontiac Grand Prix GTP L67
  13. #13 Re: whats causing this coolant leak?
    SE Level Member FASGP's Avatar
    Toronto ON
    Waterpump is done then...if it is intermittent, it may leave you stranded one of these times...
    Vtec...All the lag and none the turbo...it's like waiting for bad sex
  14. #14 Re: whats causing this coolant leak?
    Dec 2012
    troll land
    ^X2
  15. #15 Re: whats causing this coolant leak?
    SWPA
    My water pump leak was random too. Then one day started leaking like a sieve. Do it now. Its not all that hard and not all that expensive.
  16. #16 Re: whats causing this coolant leak?
    Florida
    Can anyone explain this to me, since that leak 2days ago my AC/heat has been on and off not working.?
  17. #17 Re: whats causing this coolant leak?
    in what way does it not work? no blower fan?
    and sounds like the water pump. they do leak when they feel like it, off and on for some time till they let go all the way.
  18. #18 Re: whats causing this coolant leak?
    Florida
    I flick the heat or AC on high and i hear the condenser click on but nothing blows out at all right away. Takes a few minutes sometimes or a couple tries turning it on or off.
  19. #19 Re: whats causing this coolant leak?
    thats the compressor you hear clicking on. and it sounds like your fan is crapping out. unrelated to the coolant leak for sure.
  20. #20 Re: whats causing this coolant leak?
    Florida
    Ok yea i meant compressor,well damn i just got too many problems at hand lol.
  1. Coolant leak spot found whats the fix
    By davhamm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2011, 12:06 PM
  2. What's causing vibration and leak right side?
    By rktsiens in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-30-2010, 06:25 PM
  3. What is this cap that is causing me to leak coolant?
    By utahsaint in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2010, 02:11 AM
  4. Replies: 8
    Last Post: 03-11-2010, 07:59 AM
  5. 2.8L exhaust leak, causing sluggish accleration?
    By 1988 Grand Prix in forum General Tech Discussion
    Last Post: 09-30-2009, 07:27 PM
