Thread: Engine Knocking under boost.
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 61
  1. #1 Engine Knocking under boost.
    GT Level Member natethegreat's Avatar
    Brookings, SD
    The cars top swapped with the stock pulley. I've also had the car tuned for the top swap. Anywho, put a new supercharger on last night, drove it around for a bit and seemed to drive fine. Went into boost nicely. I didn't have a knock meter up because i wasn't going to romp on it too hard. Well accidentally downshifted to 1st at 6 grand. I let off right away but after that the car would buck. Well turns out it knocks whenever its in boost. Any thoughts on what could cause this? Anything that could get knocked loose in the bay that would cause it to knock only under boost? Thanks.
  2. #2 Re: Engine Knocking under boost.
    Apr 2015
    Columbus, OH
    What map sensor you have? Who did the tune? Do you know what was changed?
    Top Swapped 01 Imp
  3. #3 Re: Engine Knocking under boost.
    why do you guys touch the shiftier after its in Drive? dont down shift these cars, its not good for the tranny. or your engine in this case.
    my guess is you broke something when you hit 6,000 rpm.
  4. #4 Re: Engine Knocking under boost.
    Brookings, SD
    Stock gtp map sensor off a 97 i think. A local guy a few years ago when i did it, and no, i think it was the stock gtp tune with some fueling/timing changed to account for the higher compression.
  5. #5 Re: Engine Knocking under boost.
    Brookings, SD
    I meant to downshift into second but pressed the gas too far.
  6. #6 Re: Engine Knocking under boost.
    news flash, a top swap tune is the settings changed to a gtp's, but cut some timing lol
  7. #7 Re: Engine Knocking under boost.
    Brookings, SD
    I mean i know nothing about tuning so wasn't sure.
  8. #8 Re: Engine Knocking under boost.
    Apr 2015
    Columbus, OH
    Oh...so this swap was done awhile ago? Only thing different is blower? So, it was running fine just until you drop shifted into 1st? No KR prior to this?
    Top Swapped 01 Imp
  9. #9 Re: Engine Knocking under boost.
    Cracking flexplate?
  10. #10 Re: Engine Knocking under boost.
    Brookings, SD
    It said it had some kr sometimes but it was never was never a lot. I took the belt off and it's still doing it. 2500/3000 rpms and starts popping, and bucking, it will kind of get out it downshift and be fine then do it again at those rpms. In just barely on the peddle enough to accelerate.
  11. #11 Re: Engine Knocking under boost.
    post a vid.
  12. #12 Re: Engine Knocking under boost.
    Brookings, SD
    https://www.youtube.com/watch?v=bspa...ature=youtu.be Hopefully this shows well enough what i mean.
  13. #13 Re: Engine Knocking under boost.
    check your spark plugs yet? that sounds like a misfire somewhat.
  14. #14 Re: Engine Knocking under boost.
    Brookings, SD
    No not yet, I don't have tools right now but I can do it later.
  15. #15 Re: Engine Knocking under boost.
    if you have not done a tune up, it maybe over due. new wires too, cause they might break when you pull them off the plugs.
    im runing 104 copper plugs gapped to 0.50 in my top swap. it seems to like em.
  16. #16 Re: Engine Knocking under boost.
    Brookings, SD
    I'll throw some new ones in tomorrow and see if that changes things. Thanks!
  17. #17 Re: Engine Knocking under boost.
    Change your fuel filter.
    Sent from A Galaxy Far Far Away
  18. #18 Re: Engine Knocking under boost.
    Brookings, SD
    well put some new plugs in and took it out. I can now drive it somewhat normally. I did some pulls from a stop at max 75% throttle and only 3ish pounds of boost and it seemed to run well. There was on spike of about 8* of knock but it was just split second. It also seemed like if i started at 30-40mph itd knock more but was alot less severe. Not sure i guess. Either way ill put a fuel filter in and see how that ends up.
  19. #19 Re: Engine Knocking under boost.
    Feb 2013
    37.295091, -121.930053
    this is what your engine is trying to do....
    www.youtube.com/watch?v=gazW7MOqHzQ
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  20. #20 Re: Engine Knocking under boost.
    Only reason I was saying fuel filter is because when mine was plugged my car would just fall flat on its face.
  1. 02 GTP Engine knocking
    By mintygp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2014, 08:48 PM
  2. 2000 GTP engine knocking. What are engine options?
    By jmhudgins in forum Introductions/Noob Questions
    Last Post: 07-29-2013, 07:46 PM
  3. Engine knocking....help
    By blortz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2010, 06:18 PM
  4. Engine Rumbling/Knocking, HELP Please :)
    By crusinchub in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2009, 06:46 PM
  5. engine knocking
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2008, 01:50 PM
