Thread: Engine knocking....help
Results 1 to 5 of 5
  1. #1 Engine knocking....help
    Calgary
    so i just did an oil change on my 99 grand prix gt 3.8 non supercharged car... and now it knocks????? it knocked before i did the oil change too but not as bad... the oil is up to level and i even used lucas oil stabilizer.....anyone know whats wrong or how i can fix it????? hopefully its not an expensive fix
    THANKS!
    also the exaust smells more like burning??? could be bad tank of gas???
    catalytic converter has been removed by professional., new o2 sensor with emmulator and new spark plugs and wires.
  2. #2 Re: Engine knocking....help
    Texas
    Did you try using a thinner oil like 5-30 or 0-30?
    That's not a good sign. Also cracked flexplates will sound like the engine is knocking.
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: Engine knocking....help
    Calgary
    i actually used a 5-30 castrol oil with some lucas oil stabilizer.... hasnt really gotten worse or better???? im new to owning a grand prix iom used to trucks... i dont know what a flex plate is..... is there anyway i can crawl under the car or something to see??? i dont wanna have to take apart the block but i will if thats whats needed to fix it... have only owned the car for a month now... no problems up until now....
  4. #4 Re: Engine knocking....help
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    Quote Originally Posted by blortz View Post
    Flexplate- Is what a flywheel is called on an automatic transmission.
    What kind of knock? Take a video of it so we can hear this knock and better diagnose the problem.
    Try using thicker oil such as 10-30 or 10-40 the thicker oil tends to quiet down problems but its not the solution to fixing noisy stuff.
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  5. #5 Re: Engine knocking....help
    Use Gear lube...like 80-90W...that'll get rid of any noise you have.
    Kidding though...
    Video FTW, like stated. Trying to diagnose something without hearing it is like finding a STD free whore in Canada
  1. knocking sound from engine
    By BSP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 09:03 AM
  2. Engine knocking - possibilities
    By GR8racingfool in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2009, 03:15 PM
  3. Engine Rumbling/Knocking, HELP Please :)
    By crusinchub in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2009, 06:46 PM
  4. Squeaky brakes/Engine Knocking
    By crusinchub in forum Brakes/Suspension/Chassis
    Last Post: 06-16-2009, 07:34 PM
  5. engine knocking
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2008, 01:50 PM
