Thread: Weird feeling issue
Results 1 to 18 of 18
Threaded View
  1. #18 Re: Weird feeling issue
    Mar 2012
    South Beloit, IL
    Ok I want to regroup my thoughts here, because I am all over the place with this one. SO:
    The issue: I will be driving down the road and the car will suddenly kill. Once it kills, it doesn't want to start back up.
    Temporary solution: Disconnect the battery for a brief moment and reconnect it
    Codes:
    - P1860 TCC PWM Solenoid Circuit (Irrelevant)
    - P0113 IAT Sensor 1 circuit high (Irrelevant)
    - P0403 EGR Control circuit (Irrelevant)
    - P0101 MAF Circuit range/performance <- I thought this was ruled out, but it wasn't.
    - P0300 Random misfire (Irrelevant)
    - P1554 Cruise control feedback circuit <- I thought this was ruled out, but it wasn't.
    Things I have tried:
    - PCM
    - ICM
    - Crank position sensor
    - IAC
    - MAF
    - TPS
    - Unplugging cruise control module
    - Anything fuel delivery related has been ruled out
    Things I plan to try:
    - Searching for a shorted wire in the harness, since both P1860 and P1554 are in regards to electrical problems
    - Ohming the injectors to make sure one is not low on impedance, causing the driver to overwork and overheat the ICM
    Other interesting things:
    - Boost/Vac gauge reads approx. 18 in.Hg and the aeroforce reads like 23?
    - I have been driving it to work, and I don't know for sure if resetting the codes is the remedy (haven't been able to do a control experiment), but I can drive for an hour and so long as I reset the codes, the car will stay running. However, because I have been driving it to work, I have been disconnecting/reconnecting the battery before I head out, just to ensure I don't break down on the interstate.
    Any other ideas?
  1. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  2. Weird Issue
    By Slick2500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2012, 01:51 PM
  3. Weird Sub Issue
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-20-2010, 10:11 AM
  4. Weird ABS issue
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2009, 12:06 AM
  5. Replies: 2
    Last Post: 10-16-2008, 05:17 PM
