Thread: NEED HELP!! im having engine issues!
Results 1 to 11 of 11
  1. #1 NEED HELP!! im having engine issues!
    Jan 2015
    Michigan
    hey guys i was wondering if anyone has encountered the same issues that i have. so i get in my car and it takes an extra second or two to turn over but then after that it is fine at idle. then i put it into drive and start driving but when i try to accelerate it bogs down and doesn't do much it kinda seems to be shutting down. it seems like it is an injector, fuel line, or fuel pump issue but i would like your input and help. Thanks!
  2. #2 Re: NEED HELP!! im having engine issues!
    we need more info. year, make model, miles. check engine light on? or does it flash when you floor it? last known tune up?
  3. #3 Re: NEED HELP!! im having engine issues!
    Aug 2013
    arlington, tx
    Sounds like an extra filthy TB to me...
  4. #4 Re: NEED HELP!! im having engine issues!
    Uh... with a title like that I expected a blown engine. Please elaborate more and fill in the details Scott asked. "Kinda seems to be shutting down" is pretty generic. Is it stalling, just bogging, does it always do it? cold vs warm? See where we are going with this, you are our eyes, ears etc.
  5. #5 Re: NEED HELP!! im having engine issues!
    Aug 2013
    arlington, tx
    Hey bill, nice sig man. Hahaha
  6. #6 Re: NEED HELP!! im having engine issues!
    SE Level Member lostscout's Avatar
    Sep 2014
    Cold Lake Alberta Canada
    check your catalytic convertor......mine plugged and I had very poor power.......eventually it (thru the egr valve) burned a hole in the roof of the intake plenum.....
  7. #7 Re: NEED HELP!! im having engine issues!
    Jan 2015
    Michigan
    it is a 2002 pontiac grand prix gt 133k. it was bogging down. although it ran at a normal temp. This morning when i started it, it would run for a few seconds then stall.
  8. #8 Re: NEED HELP!! im having engine issues!
    Jan 2015
    Michigan
    check engine light it always on now. it has a 3800 series 2 with 133k
  9. #9 Re: NEED HELP!! im having engine issues!
    if you can get the car to autozone, or most parts stores do free code reading. get the code. start there. the cel holds the key to your repair.
  10. #10 Re: NEED HELP!! im having engine issues!
    Sep 2014
    sounds exactly like what I went thru
  11. #11 Re: NEED HELP!! im having engine issues!
    Jan 2015
    Michigan
    Thanks everyone for all your input! it turned out to be a dirty MAF. im glad it was simple to fix
  1. Engine Issues
    By NHRA21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2013, 05:28 AM
  2. engine issues,please help!
    By CountryBoy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2013, 01:16 PM
  3. GTP engine issues please help!!!
    By 03GTP38k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2012, 07:46 AM
  4. Issues with the engine
    By maverickdog8 in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-24-2010, 04:23 AM
  5. Need help with a Sea-Doo, Engine Issues...
    By FastKatt in forum Off Topic Discussion
    Last Post: 07-18-2009, 01:43 PM
