Thread: car runs for 10 seconds then dies
Results 1 to 3 of 3
  1. #1 car runs for 10 seconds then dies
    Oregon
    Sorry if this has been discussed before...been searching the site for 4 months...just don't know the right keywords for my problem.
    I have a 2000 GP 3.8. have had it for 4 years, always ran perfect. 4 months ago, it started to die when put into gear. Check engine light came on...pulled code-said TPS. Replaced the TPS...no joy.Now it will start and run perfect(just don't even look at the throttle pedal) for about 10 seconds, then die
    went on here,looked at the manual...thought it might be the ECM. couldn't find a local source to reprogram a new one.
    A friend said it could be the ICM, or a coil pack. swapped out/checked with a multi-meter all of the coils-good to go
    The ECM would cost $100.00 to replace. The ICM was $140.00 to replace.
    I don't want to throw money at parts that I can't prove are bad. I don't mind spending money to fix this, but I want to know I'm on the right page before I spend the money...
    Has anyone here had similar problems? Any ideas which direction I should go? Thanks for ANY help
  2. #2 Re: car runs for 10 seconds then dies
    pull the vac line off the fuel pressure regulator on the fuel rail, see if gas comes out, or if it smells of gas. if it has any of that the fpr is bad. cheap easy fix if thats it.
  3. #3 Re: car runs for 10 seconds then dies
    Security light isnt flashing is it??
    Though that normally only lets it run for 3-5 seconds.
  1. GTP runs for a few seconds then dies.... battery light on
    By 87IROCZOWNER69 in forum General Grand Prix Discussion
    Last Post: 07-04-2014, 08:15 PM
  2. P0453 runs for a couple seconds then dies
    By aeidian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2014, 04:06 PM
  3. not your typical "runs for 3 seconds and dies" thread.
    By darkhorizon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 09:35 AM
  4. Cars starts then within seconds DIES!
    By MistyChameleon in forum General Tech Discussion
    Last Post: 07-15-2011, 03:34 PM
  5. Idles for 5 seconds then dies
    By 00grandprix in forum Engine
    Last Post: 04-30-2011, 04:32 PM
