Thread: Need help with swapping engine
Results 1 to 4 of 4
Threaded View
  1. #4 Re: Need help with swapping engine
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Put a small jack with a block of wood under the tail end of the trans, lift it up some while dropping the motor in, will make life a lot easier on you. Also, don't put the ***** bolt back in, will save you some time next pull.
    Edit: No need to pull the hood either, disconnect the hood struts and you can open it up some more, wedge a couple blocks of wood under the higher hood hinge bolt and the channel along the fender on both sides. If you have a helper, just have them make sure it doesn't move or use a ratchet strap through the inside of the car with the doors open for safety. Last pull I did was on a windy day, never budged. I do this once the chains are hooked up and all bolts removed ready to pull.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  1. Engine swapping help!!
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2014, 09:43 PM
  2. engine swapping question
    By PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 10:43 PM
  3. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
  4. Swapping Engine
    By Redgtp1999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 08:06 PM
