Thread: L36 Camaro build
Results 1 to 20 of 23
  1. #1 L36 Camaro build
    Kemmerer, Wyoming
    How much power will be made on an L36 with fully ported L67 heads, a better cam, and a combo nitrous methanol injection setup.
    I was thinking 250 at the wheels with the heads and cam, do you guys think that is a reasonable estimate?
    I read if you inject methanol with nitrous it decreases the stress that nitrous puts on everything, so I would probably try for a 150 shot of nitrous with the methanol.
  2. #2 Re: L36 Camaro build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    It won't ever make 250 on just the motor...
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  3. #3 Re: L36 Camaro build
    Kemmerer, Wyoming
    heads and cam wont make 250?
  4. #4 Re: L36 Camaro build
    Dec 2012
    Where 4T65E's were born
    L67 heads are lower compression = less power. Then the cam will help a bit but not to 250, especially with L67 heads.
    Sold.
  5. #5 Re: L36 Camaro build
    The L67's dished pistons also reduce compression, it's a combo of the two fyi.
  6. #6 Re: L36 Camaro build
    Dec 2012
    Right. He's asking about a l36 block though. Not a good setup really unless he's going boosted
    Sold.
  7. #7 Re: L36 Camaro build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    didnt even zzp's 4.1 stroker only make like 240 on the motor?
  8. #8 Re: L36 Camaro build
    Kemmerer, Wyoming
    I'm not sure how much the 4.1 stroker made, but I've kind of given up on boosting an L36. One idea I did have was to swap a set of L67 heads onto the F body camaro L36 and then do a dual nitrous water/methanol injection setup.
    in my searching, I found an australian L36 setup that had been top swapped and was using an air to air intercooler, I thought that was pretty interesting.
  9. #9 Re: L36 Camaro build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    all of those ideas would be way more finicky then a turbo setup and probably net less power. the 3800 just doesnt breath very well. certainly not well enough to warrant any N/A setup in my mind.
    air to air intercooler on a supercharged car is just stupid. thats like you trying to run a marathon breathing through a straw.
  10. #10 Re: L36 Camaro build
    Kemmerer, Wyoming
    take a look at the piping of the intercooler, does it really look restrictive?
    http://www.fullthrottlev6.com/forums...67-intercooler
  11. #11 Re: L36 Camaro build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    that is certainly a better way to do it then what i was imagining i.e. a cone filter on one side of an intercooler core and a pipe up the supercharger. with the m90 being a positive displacement blower having to pressureize all that extra volume is gonna kinda defeat the only benefit of the supercharger i would think. the guy claims no lag but im still skeptical. its an interesting concept.
    the one guy only made 310 horse on a 2.55 pulley. hell for that kind of power you could just stick an xpz cam in with some headers and some mild heads (like clean a set up) and make more power. seriously no reason to drive the m90 that hard.
  12. #12 Re: L36 Camaro build
    Kemmerer, Wyoming
    I was thinking the same thing about 310 horse and a 2.55 pulley. an xpz cam with ported heads would put down probably 100 more hp. I will have to research how effective an air to air intercooler actually is for supercharged applications.
    I would be awfully disappointed if my 2.8 pulley car made less than 300 hp at the wheels
  13. #13 Re: L36 Camaro build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    a buddy of mine had an xpz setup on a 3.0, no intercooler, had headers and it made 330 ish.
  14. #14 Re: L36 Camaro build
    Kemmerer, Wyoming
    I think some of the top xpz cam builds made like 385.
    I think installing an air to air intercooler for a supercharger would be really simple. just mount the heat exchanger and run the ducting.
  15. #15 Re: L36 Camaro build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by SgtMarshal View Post
    intercooled on a 2.6 i would believe that. zzp's test car was like 420 ish.
    looks like you are at minimum looking at egr delete, belt routing issues. PS pump clearance issues. etc.
  16. #16 Re: L36 Camaro build
    May 2008
    Schuyler, NE
    That a2a doesn't work well. You would either need to relocate the maf to right before the lim, or hack the PCM so you can run in speed density.
  17. #17 Re: L36 Camaro build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    good point! probably add an external BOV too as im sure the internal BBV would be lacking at best
  18. #18 Re: L36 Camaro build
    May 2008
    Schuyler, NE
    Possibly. It's just a sucky setup.
    Just turbo the car and be done with it.
  19. #19 Re: L36 Camaro build
    Kemmerer, Wyoming
    no pun intended?
    the maf could go right in front of the throttle body.
    Why wouldn't the BBV work?
  20. #20 Re: L36 Camaro build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    no pun intended?
    it could go right in front of the TB but that is a lot of lag time between reading the air and the engine ingesting the air. the BBV would be lacking because all it does is let the pressurized air out of the LIM back in front of the rotors in a stock setup. with all that piping that's a lot of air to release and no where really for it to go. can i ask why you are so hell bent on this? or some other setup that is not a turbo?
  1. Replies: 399
    Last Post: 08-17-2016, 01:35 PM
  2. Build all you can build S/C 3800
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2013, 12:01 AM
  3. Interesting read. 3800 camaro build. lots of info and data
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2012, 11:38 PM
  4. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  5. Epic Camaro Build
    By Odi in forum Off Topic Discussion
    Last Post: 01-05-2011, 11:10 AM
