you got me lost. lol
lol ok I did the evap canister the one by the rear gas cap last month and I just put a new EVAP Canister Purge Solenoid Valve in today the one on the back of the tb
i dont know the lay out of the sensors so well on the n/a engines. :o
double check the pig tail to the one on the engine, if you see bare wire, cracks or missing insulation, that wire is bad.
ok will check that in a minute and I replaced parts those with ac delco :)
this is what happens I let off the gas how the rpm bounces up and down
https://www.youtube.com/watch?v=K2BT-4_NaL8
your vids private.......:/
should be fixed now
your tack looks like its waving at you....... that maybe a tcc solenoid issue you ever scan it for codes? even tho the light maybe off?
yes and only codes im getting are P0449 , P0507
iac code. http://www.obd-codes.com/p0507 thats gonna f up your throttle and rpm's.
http://www.obd-codes.com/p0449 good old evap code
might be a vac leak going to get the shop to look at it tonight
its at the shop right now called and the mechanic said he thinks theres an intake leak and there going to do a pressure test
it is a intake leak going to cost $500 to fix :(
so update went and got my new vacuum elbow and new pvc valve kit both ac delco boom problem seems to be gone no sputtering when climbing through the rpms and when I let off the gas :)
We've been telling you its a vac leak forever, I even linked the p0507 dtc description on page 2. Glad you finally fixed the vac leak.
vac leak for 4 pages lol glad its fixed up...now enjoy it, but not to much. or things can go boom lol
lol thanks guys glad I only had to pay $40 instead of $500
So the intake leak doesn't exist anymore?
no car runs normal :)
