Re: Car Sputters
Check over your vac lines real good, and test for vac leaks. Not sure about the '04+ tb's, but if you have an IAC on there, you may want to remove and clean it up (don't mess with the position of it, just remove, clean, and reinstall, moving the plunger around is bad).
Re: Car Sputters
its the stock maf and the car has 265k on it
Re: Car Sputters
ok happened to me again tonight when I was going to pickup my girlfriend from work car was running then started running like crab and no power same message reduced engine power pulled code hooked up the code reader got P0068 and P0101 cleared them car ran normal again is the maf sensor shot ?
Re: Car Sputters
try a new/ used maf. they run like 40 bucks on ebay used.
Re: Car Sputters
i was going to check out Autozone or Oreillys
Re: Car Sputters
you want to stick to a oem maf. delco brand.why used is so nice. they are cheap, and work.
Re: Car Sputters
exactly what I was going to look for always use ac delco
Re: Car Sputters
ok so just put in new maf sensor and still sputtering when climbing through the rpm's and around 80-100km range don't know what it could be should I get new plugs and wires ?
Re: Car Sputters
if your at 100,000 miles or past it, your due for a tune up anyway. get iridium plugs and store brand wires with a warranty.
Re: Car Sputters
ok so had the car running and again the code P0507 came on again and same message reduced engine power getting annoyed
Re: Car Sputters
Did it start running normal immediately when you cleared the code? I know throttle body codes will cause that. That's the only code you had?
Re: Car Sputters
yes running normal when I cleared the code and yes the only code
Re: Car Sputters
took it to the shop where I get my work done on my car and the guy said he couldn't find anything wrong and he said the little sputter noise is from my mufflers because they have no backpressure and said I can drop the car off Monday night for Tuesday morning to see why the car runs rough in the morning on startup
Re: Car Sputters
http://www.obd-codes.com/p0507
Good to hear it's going to a shop, best to let them take care of it.
Re: Car Sputters
Theres a link to my video of what im talking about so annoying hope they can find out whats wrong Tuesday
https://www.youtube.com/watch?v=ib8s...ature=youtu.be
Re: Car Sputters
how are you checking for vac leaks? cause that sounds like a vac leak.
spray the vac lines with carb cleaer, if the idle jumps up you found the broken line area.
Re: Car Sputters
ok where are the vac lines I should be spraying ?
Re: Car Sputters
i cant find a n/a diagram. but its all these little hard plastic lines around the engine top and off the TB,
http://i883.photobucket.com/albums/a...0/DSCF5814.jpg
Re: Car Sputters
Ok will have to try tomorrow morning when I get some carb cleaner
Re: Car Sputters
you got two line off the front rad side of the TB that Y tends to break. or just the rubber ends to the Y or to the TB, thats a 500 rpm surge easy, its a large leak if its a vac leak. move the lines up and down while you spray, and listen for a hissing/sucking sound.
if that Y is broken or its lines to it, you can cut off the rubber end to the hard line off, get a foot of new vac line and Y stem at the parts store and replace the two lines to the TB as well. you may have to get a fatter hose for the TB then push some thinner hose inside the fat one to reduce the line to fit the the Y stem.
its a 3 dollar fix
