Thread: Rocker arms
Results 1 to 16 of 16
  1. #1 Rocker arms
    Oct 2014
    I'm redoing my headgaskets and upper intake on a 98 grand prix gt. Does anyone know what the part number or any info on where I can order new rocker arm bolts?
  2. #2 Re: Rocker arms
    Nov 2011
    NY
    Stock rocker arm bolts are tty... Replace them with these...
    http://intense-racing.com/Merchant2/..._Code=3800_HCV
  3. #3 Re: Rocker arms
    Nope replace with these rocker arm bolts that way you lessen the chance of stripping them when you go to torque them.
    Hex head suck!
    http://www.prjperformance.com/Products/
    04 Comp G.
  4. #4 Re: Rocker arms
    Nov 2011
    NY
    Hex head suck!
    Good product too... And yes, it happens. But...
    At 28-30ftlbs torque spec, shouldn't be stripping anything!
    Lolz
  5. #5 Re: Rocker arms
    I stripped plenty just getting them torqued down properly and have also had to remove them when troubleshooting and often ended up stripping.
    04 Comp G.
  6. #6 Rocker arms
    Mercer, Pa
    Why head gaskets?
    3.8 head gaskets are never an issues on stock cars. Intake manifold gaskets and upper composite intake on normally aspirated.
  7. #7 Re: Rocker arms
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    If you use the correct size hex socket I can't imagine ever stripping a rocker bolt. its snug as can be.
    04 GTP -HAI, 1.9 rockers.
  8. #8 Re: Rocker arms
    I used the correct size trust me. I was surprised myself but when it happened more then once I said enough and just went the prj route. Had no issues after that.
    04 Comp G.
  9. #9 Re: Rocker arms
    Aug 2013
    Sandy, UT
    Weird. The one I have is so tight that it won't go in if theres oil in it, it will push all the oil out. But anything can happen I suppose.
  10. #10 Re: Rocker arms
    Yea I thought it was weird and that I might of been the only one that had the problem. Shrugs.. Who knows.
    04 Comp G.
  11. #11 Re: Rocker arms
    Oct 2014
    Yeah I was told it was my head gasket however the only way to know for sure is to tear it apart. It was my upper intake...so I did all this for no reason. But when I go to torque the bolts they break at 30...
  12. #12 Re: Rocker arms
    Oct 2014
    So when we removed the belt tensioner assembly the plastic elbow that goes to the lower intake manifold snapped off...any idea on how to get that out?
  13. #13 Re: Rocker arms
    Aug 2013
    Sandy, UT
    pliers, flat head, etc. Anyway you can get a grip to slide it out. I usually (carefully) use a flat head to break it or crack it so i can spin it loose and then pull the bits out. Probably better ways though.
  14. #14 Re: Rocker arms
    Sep 2014
    United States
    Quote Originally Posted by hartc26 View Post
    Like SnowTh1ef said. I used a flat head screw driver and hammer to tap the edge until it shifted just a little then I used a set of these picks. Especially the one that looks like a hook. Be careful not to hit the intake with the flat head and hammer.
    http://www.harborfreight.com/7-piece...set-69592.html
  15. #15 Re: Rocker arms
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    yep I found out the hard way how easy those rocker arm bolts can break...
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  16. #16 Re: Rocker arms
    Oct 2014
    Same here...got it all back together now and it runs like a champ haha
  1. rocker arms
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-25-2011, 03:59 PM
  2. rocker arms
    By 02 monte carlo ss in forum General Tech Discussion
    Last Post: 02-12-2011, 09:41 PM
  3. rocker arms cam help
    By wking2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-13-2010, 04:39 PM
  4. 1.9 Rocker arms
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 03:07 PM
