Thread: Locking Harmonic Balancer into place
Results 1 to 11 of 11
  1. #1 Locking Harmonic Balancer into place
    Sep 2014
    United States
    I hope I am posting this in the right section to get help. If not can someone let me know and I will move it.
    I have spent at least 4 hours yesterday trying to break the bolt on the harmonic balancer yesterday. After using Google and the search function on this site. I understand now that they are put on crazy tight from GM and if they have never been removed before it is almost impossible to get off. What I have tried so far.
    1. Using an impact wrench 1/2" which would not budge it. After reading I realize my compressor and Impact does not have enough torque nor CFM. My compressor is a simple garage compressor from tractor supply 30 gal. max 135psi.
    2. I found a small pry bar that would fit through one of the fly wheel holes and wedged it against the block. Using a 24" breaker bar I pulled hard enough to bend the pry bar and tilt the engine stand with no luck of the bolt breaking.
    I have read post of people being successful by using stronger impact wrenches. I have also seen videos of people using the starter while the engine is in the car to break the bolt loose.
    Has anyone been successful at heating the bolt with a torch and breaking it loose. If so how considering that part of the HB is rubber.
    Next considering that the engine is already out of the car on an engine stand has anyone made a tool to hold the HB that doesn't require welding. Just simple supplies that can be found at HomeDepot or Lowes. Or maybe a tool that will lock the flywheel. As I am just a simple DIY guy that does not know how to weld.
  2. #2 Re: Locking Harmonic Balancer into place
    breaker bar, then a pipe, then lock the flex plate, have a fat friend stand on the stand and hold the engine, then someone jumps on the bar.
  3. #3 Re: Locking Harmonic Balancer into place
    May 2008
    Schuyler, NE
    I take a pair of vice grips and clamp them to the flexplate, and they lock up against the engine stand.
    Then, I use a 2' breaker bar. Have to pull pretty hard, but there hasn't been one I haven't been able to crack like this.
  4. #4 Re: Locking Harmonic Balancer into place
    Yup.. Vice grips on the flex plate. Then a long breaker bar.. And a bit of muscle should get it lose.
    04 Comp G.
  5. #5 Re: Locking Harmonic Balancer into place
    Sep 2014
    United States
    Just so I am clear. Place vice grips on the flex plate and rotate until it comes in contact with engine stand. Next pull like hell on the breaker bar ? I saw this before in a post but was afraid I would bend the flex plate or mess up the teeth. I have been letting the bolt soak in PB Blast overnight and will try this when I leave work today.
  6. #6 Re: Locking Harmonic Balancer into place
    vise grips on the flex rotate the flex so the grips hit the engine block, then large pipe on the breaker bar. have a friend stand on the the stand to keep it from flipping over on you.
  7. #7 Re: Locking Harmonic Balancer into place
    Sep 2014
    United States
    Exactly! Forgot to add fat friend part. I should probably also include a 6 pack of beer for fat friend.
  8. #8 Re: Locking Harmonic Balancer into place
    I've done the stand on engine stand, 4 foot bar on 1/2" ratchet, with vice grips etc etc. Person working breaker bar, literally jumped up to hug it with all his weight. That's what one took.
    Usually.. air gun will rip them off.
  9. #9 Re: Locking Harmonic Balancer into place
    Sep 2014
    United States
    I was able to break the bolt last night with a little help. It actually made a loud pop. I wasn't sure a first what it was I thought I broke something. As you can see in the pic. I used some vise grips and piece of rebar through one of the flywheel holes. It definitely took 2 people. One standing on the engine stand while the other leans on the breaker bar with all their weight.
    Thanks again for all the help.
  10. #10 Re: Locking Harmonic Balancer into place
    Yeah.. when my buddy jumped on it.. he said. We are either going to loosen it or break it.
  11. #11 Re: Locking Harmonic Balancer into place
    Mercer, Pa
    My friend was 12 and weighed 100 pounds. I put the engine on the Ground and wedged a 6 foot spud bar under exhaust manifold. 12 year old was able to hold motor from flopping while I pulled.
  1. Harmonic balancer
    By dezebe1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2014, 10:19 PM
  2. Harmonic balancer
    By Tone5500 in forum General Tech Discussion
    Last Post: 11-13-2013, 08:01 AM
  3. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  4. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  5. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
