Thread: Top Swapping, what do I need to know?
Results 1 to 5 of 5
  1. #1 Top Swapping, what do I need to know?
    May 2014
    New Mexico
    Hey guys,
    I'm top swapping my 02 GP GT in 2 weeks, what all do I need to know? I've heard that on a Top Swap a 3.8" pulley is the same as a 3.6" on a GTP. What's everything important I need to consider? Tried to search the forums but didn't find much. Links to other threads would be appreciated as well.
    Thanks!
  2. #2 Re: Top Swapping, what do I need to know?
    you didnt search nearly hard enough then. http://www.grandprixforums.net/threa...s-of-3800-Info
  3. #3 Re: Top Swapping, what do I need to know?
    Apr 2012
    Bancroft. Ontario, Canada
    the search box is your friend
  4. #4 Re: Top Swapping, what do I need to know?
    May 2014
    New Mexico
    "Top Swap" in search bar yields me no relevant results.
  5. #5 Re: Top Swapping, what do I need to know?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    You have everything you need for a top swap?
    -Heads
    -LIM
    -Blower
    -Tensioner
    -GTP PCM
    I'd suggest to do headers with the top swap. Its the perfect time to install them. Grab some Speed Daddy's off eBay for $220. You'll be on a high compression block, with stock manifolds that breathe no better than coffee straws, and a blower that makes a bunch of heat. It's asking for trouble. In that case, headers should be necessity, especially when they can be had for so cheap.
    I don't know what your budget is, but if I was going to top swap, I'd do the majority of mods I wanted to do now, such as Springs/rockers/Gen V/Northstar throttle body.
  1. Top swapping
    By stockGTforlife in forum General Grand Prix Discussion
    Last Post: 09-26-2013, 11:46 AM
  2. swapping
    By ssiebor14 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2013, 10:01 PM
  3. 98 GTP swapping non S/C 3.8
    By brktracer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2013, 09:07 AM
  4. swapping
    By coreysGTP in forum Introductions/Noob Questions
    Last Post: 12-28-2012, 10:35 PM
  5. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
