Thread: Help me Build the fastest N/A 3800! Will keep updated
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #1 Re: Help me Build the fastest N/A 3800! Will keep updated
    May 2012
    Where winter never ends
    LOL. Seen em go for like 450 or less....
    Entire top of a SC engine... Heads, Lim, SC ect.
    2000 Regal - Winter Beater
  2. #2 Re: Help me Build the fastest N/A 3800! Will keep updated
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    IF you bargain hunt and get used parts you can grab a gen 3 m90 lim heads balancer and fuel rails for 300-400. rock out some headers, rockers and all the associated gaskets and a correct size pulley and you're rocking a 240-260 whp setup on gas on gtp injectors or close to 280-300 whp on big injectors and e85. all for less than 1200-1400.
    Where as this mod list:
    Plog
    HV3
    High Velocity TB
    2.5" catless DP (no emissions where I live so it's extremely easy to get away with)
    TR6
    10.5mm wires ZZP
    Bigger fuel injectors? Not sure if this actually does anything for HP.
    ZZP GT cam unless I can get a more aggressive one. Not sure if they're compatible. OR rockers
    and eventually,
    ZZP heads.
    Where else can I go with this?
    Idea's? thoughts? I want to get started on this ASAP. I have a few basic things done
    Straight pipe after the CAT
    180T
    CAI
    TR6
    10.5 wires
    will run you well north of 2k.
    I LOVE my top swap. Better than any NA setup on these cars garenteed. bone stock (no headers or rockers or anything) it ran 14.6 on crap tires.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: Help me Build the fastest N/A 3800! Will keep updated
    I break stuff selliott's Avatar
    Kansas City
    Top swap or turbo enough said. Personally I'd just go turbo and be done with it, believe me I've wasted a ton of money trying to over build my engine.
  4. #4 Re: Help me Build the fastest N/A 3800! Will keep updated
    What are your goals? If you are hell bent on NA most power, go read the internet until your eyes bleed on all the 3800 forums you can find. You likely will come up with tons of dollars spent for gains that could be had cheaper/easier on different options like turbo/SC.
    I'm not going to sit here and tell you that the car sounds bad based on you straight piping it. My Regal with GTP catback (no res, high flow cat) sounds amazingly fine even on the throttle. It's an oddball. Most 3800's with any exhaust mods (and stock) sound like crap. They have rasp and drone. Your's might be an oddball too.
    Many will tell you to turbo or top swap etc. Personally, I've learned a ton from this platform....and broken more than I like to admit. That's expensive and at the end of the day I gave up on the platform and sold off the performance stuff. There are many other cars that handle/make power better than the 3800/4T65 combo. That's not saying it doesn't do well for the mass produced setup that it is.
  5. #5 Re: Help me Build the fastest N/A 3800! Will keep updated
    Mar 2012
    NC
    I can't agree more. I've done a NA 3800 build...ported heads, cam, rockers, headers, exhaust...it was quicker than stock, but nothing drastic. You're going to be spending a ton of cash just in one-off parts like high compression pistons plus TONS of machine work if you actually plan to make anything decent. Plus, there will come a point where you'll hit a ceiling and no more power gains will be left on the table and you'll be uber modded to the point where you'll have to find a different block or swap the rotating assembly just so you can ultimately go forced induction to get the power you wanted to be at in the first place. I'm all for being different, but where do you really want to end up?
  6. #6 Re: Help me Build the fastest N/A 3800! Will keep updated
    Aug 2011
    'Merica
  7. #7 Re: Help me Build the fastest N/A 3800! Will keep updated
    GT Level Member blownGP's Avatar
    Sep 2013
    Iowa
    My car sounds like ass and it has stock mufflers lol
    2000 2500 Chevy with 6 inch lift build thread- http://www.gmt400.com/forum/showthre...d-Crew-Cab-454 2006 Grand Prix supercharged build thread- http://www.grandprixforums.net/blown...ead-82585.html
  8. #8 Re: Help me Build the fastest N/A 3800! Will keep updated
    Aug 2013
    McDonald PA
    Quote Originally Posted by blownGP View Post
    Yepp if you wanna stay NA like bill and a few others. Then put money into your suspension and have fun tossing it into some corners. I'm considering auto x my car
  9. #9 Re: Help me Build the fastest N/A 3800! Will keep updated
    Whoaaaaa ... Learn your cars buddy. I have a Regal GS. GS means... Granny's (FAWKIN) Supercharged I went NA when a whore left -$300 in my bank account and the choice was $300 for an NA with 50K or $700 for SC with billion miles.
  10. #10 Re: Help me Build the fastest N/A 3800! Will keep updated
    Aug 2013
    McDonald PA
    Woahh not knocking lol and when are you gonna pm me back haha
  11. #11 Re: Help me Build the fastest N/A 3800! Will keep updated
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I have diy intake, hv3 insert, headers,91 octane tune. And I can keep up with stock gtps and I'm happy with that but it's all what your looking for hp wise.I had a top swap but decided against it because all the top swap issues. if I want to be fast I'll buy a fast car lol
  12. #12 Help me Build the fastest N/A 3800! Will keep updated
    Aug 2013
    McDonald PA
    ^ not a gp basically lol
    edit WBody
  13. #13 Re: Help me Build the fastest N/A 3800! Will keep updated
    Skip all that n/a crap and just topsaap or turbo and make more power then what your going to end up with.
    04 Comp G.
  14. #14 Re: Help me Build the fastest N/A 3800! Will keep updated
    Sep 2013
    Iowa
    Honestly if it was me I'd drive the n/a stock till I could afford a turbo and tep
  15. #15 Re: Help me Build the fastest N/A 3800! Will keep updated
    Or just topswap because it can be done for cheap!
    04 Comp G.
  16. #16 Re: Help me Build the fastest N/A 3800! Will keep updated
    Aug 2013
    McDonald PA
    I would probably top swap. It's gonna be more reliable in the long run cheaper and can easily with a few bolt ons and a tune out smack the fastest NA
  1. Build all you can build S/C 3800
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2013, 12:01 AM
  2. Build Thread: Addicted to L67's~updated 4/6/2013
    By 88formula in forum Members Rides
    Last Post: 04-26-2013, 11:14 PM
  3. Replies: 89
    Last Post: 11-20-2012, 11:30 AM
  4. if you could build your dream 3800 motor what would you use
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2010, 12:30 PM
  5. Fastest 3800 for sale!
    By Dboy23 in forum Off Topic Discussion
    Last Post: 11-03-2008, 12:26 AM
