IF you bargain hunt and get used parts you can grab a gen 3 m90 lim heads balancer and fuel rails for 300-400. rock out some headers, rockers and all the associated gaskets and a correct size pulley and you're rocking a 240-260 whp setup on gas on gtp injectors or close to 280-300 whp on big injectors and e85. all for less than 1200-1400.
Where as this mod list:
Plog
HV3
High Velocity TB
2.5" catless DP (no emissions where I live so it's extremely easy to get away with)
TR6
10.5mm wires ZZP
Bigger fuel injectors? Not sure if this actually does anything for HP.
ZZP GT cam unless I can get a more aggressive one. Not sure if they're compatible. OR rockers
and eventually,
ZZP heads.
Where else can I go with this?
Idea's? thoughts? I want to get started on this ASAP. I have a few basic things done
Straight pipe after the CAT
180T
CAI
TR6
10.5 wires
will run you well north of 2k.
I LOVE my top swap. Better than any NA setup on these cars garenteed. bone stock (no headers or rockers or anything) it ran 14.6 on crap tires.
