Thread: Skipping, Misfire Problem
Results 1 to 12 of 12
  1. #1 Re: Skipping, Misfire Problem
    spray some soapy water around and you'll find the spark leak easily.
  2. #2 Re: Skipping, Misfire Problem
    Why soapy? Regular water works just fine.... or are you suggesting he clean things during diagnosis? lol
    The coil winding test can be misleading. Even if the coil has a break..likely when you test it....it'll test fine. Since you heard the arching.. wait til it's dark and mist the engine while running. Once you find it..likely you'll be all set.
  1. p0300 misfire problem
    By poorkid in forum General Tech Discussion
    Last Post: 08-22-2013, 04:52 AM
  2. Replies: 4
    Last Post: 04-05-2013, 08:11 PM
  3. misfire problem
    By Silversurfer Gio in forum General Tech Discussion
    Last Post: 05-31-2012, 07:02 PM
  4. strange misfire problem
    By boostedcompg in forum General Tech Discussion
    Last Post: 09-21-2011, 09:43 AM
  5. Cylinder 6 misfire problem.
    By Glides in forum General Tech Discussion
    Last Post: 09-28-2009, 05:35 AM
