Thread: Coolant Leak
Results 1 to 6 of 6
  1. #1 Coolant Leak
    SE Level Member 99grandprixman's Avatar
    Jan 2013
    Goodyear, AZ
    Hey guys, recently, my '99 GT began leaking coolant at a pretty heavy rate. I replaced those dreaded coolant elbows about 6 months ago, and the leaking stopped for a while. I was just wondering, if those could be the culprit again, or if its something else like the intake gasket. Thanks
  2. #2 Re: Coolant Leak
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    could be anything my friends 98 gt had a hole in the heater hose would just have to look
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Coolant Leak
    if its leaking by the belts again, then it could be the water pump.
  4. #4 Re: Coolant Leak
    Jan 2013
    Goodyear, AZ
    After further investigation, at least one of the coolant elbows is bad. The plan for now, is I'll buy the aluminum ones from zzp, and hopefuly they last longer.
  5. #5 Re: Coolant Leak
    Buy from Rockauto they are cheaper
  6. #6 Re: Coolant Leak
    Jan 2013
    Goodyear, AZ
    I would have...but its too late. haha oh well..
  1. Coolant Leak
    By Egleone6 in forum General Tech Discussion
    Last Post: 08-16-2012, 08:09 AM
  2. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  3. Need help..coolant leak
    By Ktrap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 11:20 AM
  4. coolant leak
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2011, 11:56 PM
  5. coolant leak
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-15-2011, 07:44 PM
