Thread: Help with coolant leak
Results 1 to 9 of 9
  1. #1 Help with coolant leak
    Dec 2008
    California,Md
    I just purchased a 1997 Grand Prix Se with 145000 miles on it.When we brought it home the other day the radiator was full.This evening went and looked under the car and there was nothing on the ground.Started it for about 5 minutes and then after I shut it off there was a puddle about 5 inches around.I cannot find anywhere it could be leaking from because it seems to far back to be from the radiator.The fella I got it from said he thoguht it was a water pump and replaced it before I got ithe car.It is currently at the shop being looked at but I thought you guys may have an idea or 2.I am just hopeing that its not anything major the car runs great .Any help would be greatly appreciated.Thanks...Dont know if this matters but the car does NOT smoke at all.
  2. #2 Re: Help with coolant leak
    chicago
    is it a 3100 or 3800? i think it's the coolant elbows
  3. #3 Re: Help with coolant leak
    Dec 2008
    California,Md
  4. #4 Re: Help with coolant leak
    I live here. UR LOSN's Avatar
    Rockford, IL
    well. when he replaced the water pump, he could have not tightened down a new hose clamp? properly torqued the bolts? broke a coolant elbow?
    could be a few things.....
  5. #5 Re: Help with coolant leak
    PA
    Or he could have not put thread sealant on the bolts when he installed the water pump. Could be a bunch of possibilities.
    2001 GSE
  6. #6 Re: Help with coolant leak
    Oklahoma
    I didnt put thread sealant on my bolts when I installed a new water pump. Not that I recall anyway.
  7. #7 Re: Help with coolant leak
    PA
    The bolts go directly into the coolant passages. Sometimes you can do them without sealant and they won't leak. Sometimes you can do them with sealant and the will leak. In my opinion, it is a bad design to have bolts go directly into a coolant passage. But what do I know.
    2001 GSE
  8. #8 Re: Help with coolant leak
    Oklahoma
    I would agree with you on that. I guess before I put the engine back in the car I'll seal them up just for good measure.
  9. #9 Re: Help with coolant leak
    Dec 2008
    California,Md
    Well the shop found a leak at the elbow so as I type they are refilling the system and presure checking it.Hopefully that will be all..Thanks for all your ides.
  1. suspected coolant leak into oil
    By e56505 in forum General Tech Discussion
    Last Post: 02-16-2009, 03:18 PM
  2. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
  3. Vehicle problems - won't run, coolant leak
    By boogsey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2008, 10:17 AM
  4. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
  5. Opinions on possible coolant leak
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2008, 11:00 PM
