Thread: Heater Not Very Strong?
Results 1 to 20 of 27
  1. #1 Heater Not Very Strong?
    Sep 2012
    Cedar Rapids, Iowa
    When I have my A/C on during the summer it works great, real strong and everything. However when I use the heater it makes the car warm and if I put my hand up to the vents it feels warm however I feel little to no air blowing out of it. Any ideas why this might be?
  2. #2 Re: Heater Not Very Strong?
    I'm sure if you searched on this topic, you'd find several hundred threads regarding heat problems in the winter time.
    Take some time and do some reading and maybe you'll figure it out.
  3. #3 Re: Heater Not Very Strong?
    Sep 2012
    Cedar Rapids, Iowa
    I already did a search around of it on here and online, only found 11 threads matching "heat problem" in the thread title. Most of them cited some problem with the blower motor, but if the blower motor didn't work my A/C wouldn't work either correct?
  4. #4 Re: Heater Not Very Strong?
    GTP Level Member
    springfield IL
    Check the hater core lines back by fire wall.. Should be hot
  5. #5 Re: Heater Not Very Strong?
    GTP Level Member
    Aug 2012
    st louis park, MN
    I don't think the heater core has to do with air flow coming out of the vents only the temp of the air. I can't necessarily help MattF but continue different searches like "heater" "heat issue" "heat" etc and see if you find any better information. I'm sure someone more knowledgeable will post up soon.
    I'd post some more info too like is this the first time you've had the problem, year of car etc.
  6. #6 Re: Heater Not Very Strong?
    Mercer, Pa
    Which thermostat are you running? I put 195 back in during winter to get more heat. Make sure you are not low on coolant and you don't have sludge build up in radiator. Sludge can actually stop the flow of coolant through heater core.
  7. #7 Re: Heater Not Very Strong?
    Sep 2012
    Cedar Rapids, Iowa
    The heater has no problem producing the actual heat as I have stated because when I push my hand up to the vent I can feel warmth and it has no problem heating up the car, there is just very little air flow coming out of it which causes it to take longer to heat up the car.
  8. #8 Re: Heater Not Very Strong?
    Dec 2012
    Where 4T65E's were born
    So is a good amount of air coming out of any of the vents? On high speed of course. If not the heater core may be clogged (externally)
    Sold.
  9. #9 Re: Heater Not Very Strong?
    Mercer, Pa
    Quote Originally Posted by MattF View Post
    Then you have a fan problem.
  10. #10 Re: Heater Not Very Strong?
    Dec 2012
    Quote Originally Posted by sseilmnop View Post
    Well he said using the A/C blows strong. The air doesn't go through the heater core when in the cold air selection. So the blower may be fine.
    Sold.
  11. #11 Re: Heater Not Very Strong?
    Mercer, Pa
    He said in the summer it blows strong. Does the ac blow strong now?
    Did he check his coolant level?
    Did he check for sludge?
    What year make model of car?
    Digital climate control or manual?
  12. #12 Re: Heater Not Very Strong?
    Sep 2012
    Cedar Rapids, Iowa
    Coolant level is fine but I haven't checked for sludge. 2002 Grand Prix GT. Manual Climate Control.
    A/C blows fine now I have tested it. And even now, my car sits outside so when I get on and turn the heat up all the way the air is cold but blows strong, when it starts to get warm the force of the air coming out of the vent gets diminished.
    It's pretty linear across all the vents, none of them are blowing stronger than any of the other ones although every once and a while the air coming out of them will get a bit stronger.
  13. #13 Re: Heater Not Very Strong?
    run the a/c for a while, see if the fan slows down in the same time as the heat.
    thinking your fan is dead. how does it sound? any vibrations, or sounds from it?
  14. #14 Re: Heater Not Very Strong?
    Dec 2012
    So wait, you have the selection on lets say, the face vents, but the air is coming out of all vents about equal? That shows that the actuators may not be in the correct spots.
    And only when the car is warmed up? That's odd. yeah maybe it has to do with the blower warming up and going slower like scotty said?
    Sold.
  15. #15 Re: Heater Not Very Strong?
    Mercer, Pa
    Did you check coolant level in the overflow tank or in the radiator?
    Fan doesn't blow hot air, it takes outside air and blows it across the heater core to get heat.
    Is there a recirculate option?
  16. #16 Re: Heater Not Very Strong?
    Dec 2012
    I meant that as the blower motor itself warms up from the electrical current and acts up.
    Sold.
  17. #17 Re: Heater Not Very Strong?
    Mercer, Pa
    Should be a brushed DC motor with fan speeds controlled by a resistor bank. Hi speed doesn't go through a resistor.
    Not common for these motors to slow down from heat. Resistors go bad and electrical connections overheat and go bad but it normally works or it doesn't.
  18. #18 Re: Heater Not Very Strong?
    Dec 2012
    I know. I didn't really think the blower motor was bad, it's just odd how it blows fine at first. Also the coolant level has nothing to do with the amount of air that is pushed through the vents.
    Sold.
  19. #19 Re: Heater Not Very Strong?
    Nov 2012
    Tennessee
    Ok I dont know too much about the electrical stuff but when he said the fan blows fine on heat at first and then as the car warms up it slows down..... could it be the sensor that detects when the cabin is warmed up to the set temperature on the controls... i mean... i can turn the knobs for any temperature between 60 and 90 and the auto controls will slow the fan when the cabin reaches the desired temp. could it be that sensor or whatever controls it.... just a thought.....
  20. #20 Re: Heater Not Very Strong?
    Mercer, Pa
    Can't you override the fan speed? Is this automatic temp control or full manual with just hot cold knob.
  1. strong exhuast smell
    By chris99gtp in forum General Tech Discussion
    Last Post: 09-07-2012, 07:09 PM
  2. is it norm. to have a strong smell of gas to come from the exhuast?
    By taman86 in forum General Tech Discussion
    Last Post: 02-24-2011, 11:20 PM
  3. 02 GTP strong gas smell when idleing
    By Wigglesworth in forum General Tech Discussion
    Last Post: 11-09-2010, 09:25 PM
  4. 1500 Members strong!!!
    By UR LOSN in forum Off Topic Discussion
    Last Post: 07-12-2008, 09:09 PM
  5. Six Months Old and Going Strong
    Last Post: 06-16-2008, 02:39 PM
