Thread: is it norm. to have a strong smell of gas to come from the exhuast?
Results 1 to 20 of 29
  1. #1 is it norm. to have a strong smell of gas to come from the exhuast?
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    to finish the title, is it normal to have gas smell coming from the exhaust when running an aftermarket exhaust. not too familiar with gp's, ls's mostly and it is normal when going to headers or removing the cats. to be more specific my 97 gtp has flowmaster exhuast and nothing else done to the exhaust, so stock headers, dp, cat. its noticable just about anytime its running, so driving or ideling. anybody else have this issue or any thoughts on this?
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  2. #2 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Florida
    You shouldnt be smelling any gas from the exhaust if you still have a cat.
    Now, if the exhaust is brand new, you will have a burn-in time typically, in which you get some strange smells..but it goes away after some heat cycles...
  3. #3 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Nov 2010
    south east AZ
    ya still have the stock cat and the exhaust is deffinately not new
    01 T/A WS6-SOLD
  4. #4 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Florida
    Umm, then you're probably running rich, if you're smelling fuel from the exhaust...
  5. #5 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Nov 2010
    south east AZ
    ok, so what would cause it too be running rich? maybe the maf or something?
    01 T/A WS6-SOLD
  6. #6 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Troy OH
    maf would throw a code.
    next question, is it throwing any codes? misfires? check your plugs and wires, you might have a dead cylinder and unburnt fuel coming out the exhaust
  7. #7 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Nov 2010
    south east AZ
    no codes, and runs fine besides bogging sometimes which im discussing on another thread which i have been lead to be a possible plugged cat. but other then that, not codes, no missfires
    01 T/A WS6-SOLD
  8. #8 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Troy OH
    well that would be the reason. it probably messed up the post-cat o2, so it's sending a bad reading and the pcm is making you run super rich
  9. #9 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Florida
    ^^ My thoughts..
    If its bogging under heavy acceleration, or when going up hill, its probably a Catalytic...
  10. #10 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Nov 2010
    south east AZ
    Ooohhhh ok, so if its clogged then its not allowing the post cat o2 to read correctly and since its not reading correctly its trying to compensate by adding more fuel cuz really its only reading air not burned fuel. I get it, so cat it is
    01 T/A WS6-SOLD
  11. #11 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Florida
    Hit the nail right on the head...My car did the same thing.
    Grab some headers, and be happy!
  12. #12 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    TN
    Im sorry for cuting in but it seems that his problem has been solved.
    I have the same problem but with no boging down. I only smell gas when it just started or its running cold.
    what would cause this by the way the car has back fired from a bad plug but all plugs have been replaced
    88 fiero formula l67
    04 ninja
  13. #13 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Florida
    Well, if you have no catalytic converter, its normal to smell some gas.
    If you do though, you're probably running a little rich.
    On start-up, you will smell some, because the cat isnt hot enough to do its job for a tiny bit.
    Could be a bad o2 sensor.
    Now if it's a very strong gas smell, then it's running rich as hell.
  14. #14 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Troy OH
    possibly an ignition issue. check your wires at the coil packs and spark plugs, pull the plugs out and see if one is discolored and such.
  15. #15 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    TN
    the smell is pretty strong outside the car for a couple mins after starting.
    One of my mods are a ported tb, but that should make it run lean.
    today im going to try to get my dhp working and after that i will pull the plugs again[last time one got damage from high heat]
    04 ninja
  16. #16 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Hang in a second guys. The downstream o2 (one after cat) does not control any fueling at all in 97-03 car. It has one purpose, to monitor the emissions. That's all. It can only post a code that makes you fail emissions.
    Your front sensor in the rear exhaust manifold can get lazy etc and cause you to get too much fuel. That should then murder the catalytic and trip the code for poor emissions, based off the reading from the rear o2.
    Since you have some bogging, it's possible you have a clogging cat from the excessive fuel.
  17. #17 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Thank you for saying this!! I was thinking the whole time that their down stream O2 wouldnt decide fuel trims.. I was getting lost in my own thoughts
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  18. #18 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Troy OH
    wouldn't a clogged cat throw a code too?
  19. #19 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Nov 2010
    south east AZ
    Hang in a second guys. The downstream o2 (one after cat) does not control any fueling at all in 97-03 car. It has one purpose, to monitor the emissions. That's all. It can only post a code that makes you fail emissions. Your front sensor in the rear exhaust manifold can get lazy etc and cause you to get too much fuel.
    What?! if the rear 02 doesnt do anything but throw the code then it wouldnt be there. the front 02 is more then effective to do that by its self if it is running too rich or too lean for an extended perior of time i believe. the pcm is programmed to read the 02 within a preset limit. if the rear 02 isnt reading what the pcm is programmed to read such as running lean then the pcm will add fuel, not the 02 my bad for posting that above. now that being said i can see where you said that it throws a code, cuz if its reading out of limits after the cat then it should throw a code, not the front.
  20. #20 Re: is it norm. to have a strong smell of gas to come from the exhuast?
    Nov 2010
    south east AZ
    try figuring out a code on a 4th gen f-body v8. 4 02 sensors, 75 bucks a pop just to figure why its getting "lean conditions on left and right oxygen bank". change all of them, reset computer, drive for 10 minutes, ses light, same thing. change the cats or go cat-less and get 02 sims or have a buddy with hp tuners erase the code from the computer
    01 T/A WS6-SOLD
  1. 02 GTP strong gas smell when idleing
    By Wigglesworth in forum General Tech Discussion
    Last Post: 11-09-2010, 09:25 PM
  2. exhuast
    By davisg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2008, 05:58 PM
  3. 1500 Members strong!!!
    By UR LOSN in forum Off Topic Discussion
    Last Post: 07-12-2008, 09:09 PM
  4. Six Months Old and Going Strong
    Last Post: 06-16-2008, 02:39 PM
  5. Exhuast with no mufflers
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-22-2008, 01:39 PM
