Thread: P0305 code
Results 1 to 9 of 9
  1. #1 P0305 code
    Jun 2013
    Charlotte, NC
    OK..here I am again. Earlier posts by me on this subject are now moot. Quick synopsis:
    2000 GPGT 3.8 ~230k miles
    New plugs
    New coils
    New ICM
    New wires
    p0305 code is now showing
    Compression shows ~60 on cylinder 5
    Compression shows ~70 on cylinder 3
    Car was running OK earlier, with minor engine knock. A more than normal acceleration created louder knocking, which then activated the idiot light.
    Injectors swapped between 3 and 5 did NOT migrate the problem.
    I have earlier seen this problem mysteriously vanish for some days....but again appear. OK, short of extensive (and expensive) engine exploration i.e. ripping it down, is there anything that I should also consider?
    Don't want to flush my GP...
    Thanks,
    Joe
  2. #2 Re: P0305 code
    That compression is super low. Check all the cylinder's compression and see if the gauge just may be reading wrong.
  3. #3 Re: P0305 code
    Jun 2013
    Charlotte, NC
    TY dsmuts. This was a running compression test to isolate for weak valve springs. The 100 PSI spec is for a "static" compression test (fuel and ignition disabled and tested while cranking). I'm getting closer and closer to the toilet handle daily...
  4. #4 Re: P0305 code
    Jun 2013
    Charlotte, NC
    OK...It's been a bit but here's the latest. Idiot light is ghosting....one day on...and then it's off. When idiot is on P305 is reported. And usually when on, loud lifter noise is heard.
    This is a short vid to hear the tap ...> http://youtu.be/b3FT7U64Ukw WHEN IT'S FAILING...
    I changed oil recently, and some metalics were found, but with 230k I kinda expect that. Last oil change done with 1qt MMO about 1k ago. Right now, car is normal...no light..no tap..but I am thinking about replacing the lifter(s).
    Your thoughts???????
  5. #5 Re: P0305 code
    does sound like a sticking lifter and that would make sense with the metal you found. do you still have the metal you found? was it copper colored, or silver? was it chunks? or just grit?
    mine will tick in the summer time if im over due on my oil change, but only like 3 ticks (once in a while) then it stops, oil change fixes it again.
    if its not a sticking lifter, like in the bore. and its bleeding off (loosing pressure over night) GM says its ok if it stops with in a minute or two.
  6. #6 Re: P0305 code
    Jun 2013
    Charlotte, NC
    Unfortunately, no I do not have nor seen the reported matalics. Oil Change was done by my mechanic as the car was there for a starter repair and I had him change the oil while it was up on the lift. The tap is not seasonal, nor time-of-day dependent. I have another mechanic that I saw earlier today. I barter my I.T. services with him, so any labor will be reasonable. Only other suggestion is an engine swap...i.e. get one from a junk yard. I think that replacing a lifter and any related components is a safer bet (and cheaper) then rolling the dice on a absolute unknown.
  7. #7 Re: P0305 code
    if its been suggested to get a used engine by a trusted mechanic, may as well do it. your vid there dont sound health at all really.
    those n/a engines can be found with low miles and for about 300 bucks. not so bad really. change the lim gaskets and a few other little up grades and your back on the road.
    this is a super charged lim, but your n/a lim has these 2 holes too, seal them off and the car will never have a chance to hydro lock again. print it out have your friend plug these holes for ya. http://www.grandprixforums.net/showthread.php?t=46931
  8. #8 Re: P0305 code
    Mine sounded like that and 3 lifters had exploded and the pushrods were damaged. I'd swap the lifters and pushrods
  9. #9 Re: P0305 code
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    id change the lifters out check rods and go from there
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  1. P0305 code
    By Cibargar69 in forum General Grand Prix Discussion
    Last Post: 11-09-2013, 02:06 PM
  2. Cylinder 5 misfire trouble code P0305
    By michellebuck76 in forum General Tech Discussion
    Last Post: 04-11-2013, 06:02 PM
  3. p0101, p0205, p0305?
    By Knightmare in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2011, 11:08 PM
  4. P0305 and P0401 96 3.1L Fixed
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-13-2008, 08:49 PM
